Old 07-14-2008, 11:01 PM   #121 (permalink)
othergames's Avatar
New Blue - '08 Civic EX Sedan
90 day: 36.68 mpg (US)
I'm just curious what over-the-counter cleaning agent would mar GLASS.
Old 07-14-2008, 11:09 PM   #122 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Blue Jay - '97 Metro
90 day: 50.71 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
They are not glass, but Lexan plastic. Sanding off the dried and cracked clearcoat applied by the previous owner achieved nothing, so I decided to use some brake/parts cleaner on them to soften the clear coat and could see the stuff sorta melting off, but as soon as it evaporated, the entire lense turned white. That is why I am interested in the older style lights that have the classic headlamp bulbs in them. I may lose some MPG's in aerodynamics, but I have to be able to see.
Visibility is very important to me. In the winter months around here it's dark when going to work and dark coming home. I am driving a Metro and one deer that I was not able to see can kill me faster than an alcohol induced coma.
Old 07-14-2008, 11:12 PM   #123 (permalink)
othergames's Avatar
There's nothing more important on a car than:
1.) Brakes
2.) Steering
3.) Visibility
You, well ... die without them if you drive.
Old 07-14-2008, 11:15 PM   #124 (permalink)
02 Golf TDI Driver
The Golf - '02 Golf GLS TDI
Last 3: 57.98 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
I've done this before on a MKIV Supra, follow my directions, but maybe start at 600 grit and you will be golden.
Old 07-14-2008, 11:16 PM   #125 (permalink)
I can haz veggieburger?
Formula413's Avatar
Sleepwalker - '97 Firebird Formula
90 day: 21.11 mpg (US)
Spock - '92 VN750 Vulcan
90 day: 57.55 mpg (US)
ciVic - '03 Civic Hybrid
Originally Posted by dremd View Post
Assuming you have polished headlights before (I'm thinking you have) just toss them.
If not then here it goes
1) sand with 1000 grit until everything looks the same
2) sand with 2000 grit until everything looks the same
3) Medium rubbing compound until everything looks the same
4) Fine rubbing compound untill everything looks the same
5) Plastic polish to a high gloss
It is actually a good bit of work; on a bad headlight it might take an hour each.
What do you use for plastic polish? Where can it be purchased?
More choices...
Originally Posted by bgd73 View Post
I do not exist sometimes.
Old 07-14-2008, 11:36 PM   #126 (permalink)
02 Golf TDI Driver
Here is the one that I have 3M 39010 Plastic Polish
I bought it from Oreilly Auto parts many years ago. I have probably polished at least 10 cars headlights by now and still have some (I don't know how much) left.
A buddy has a bottle of Mothers plastic polish Mothers Plastic Polish (8 oz.) in his garage; I have used it before it works about the same and is available from Walmart in the automotive cleaners and polishes area.
I have never used the Meguiars Clear Plastic Cleaner Polish But I assume it works fine as well ( I think Auto zone has this one)
The harder things to find is the 1000 and 2000 grit sandpaper.
If you go to a auto body store they will sell it in 1/2 sheets (mine does) for about $1.50 each (I don't get any discount). If you can find 3000 your job will be Much easier, but it is hard to locate.
edit: I THINK I have seen headlight restoration kits at Walmart; they have little pouches of everything, bits of sandpaper and are about $15
Old 07-15-2008, 02:59 PM   #127 (permalink)
Shadetree Engineer
Tango Charlie's Avatar
Olivia - '03 Vibe
90 day: 37.26 mpg (US)
Try a Micro Mesh kit from Sporty's Pilot Shop. It's the "industry standard" in removing scratches/haze from plastic aircraft windshields. Take it from an old A&P mechanic.
Micro-mesh Scratch Remover Kit - Sporty's Pilot Shop
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 07-15-2008, 04:29 PM   #128 (permalink)
ah... the old 'I accidentally got the brake Kleen on the Lexan' trick. I've seen that happen on racecar windows... most guys buy or build new windows at that point.
For guys who don't understand, this nasty cleaner stuff is like acetone, it melts the plastic surface completely opaque. You'd likely get more light through white spray paint
Johnny, your time is worth something, I'd ditch those things and choke it up to experience, find some replacements to work with and polish out. The lexan cover might come off the reflector housing with these little stainless clips, I'll have to look again. I bought mine at Pick-N-Pull for $30 each side, but I bet you could find a better deal if you shopped.
If not, my offer still stands on the early style ones I am removing
Old 07-18-2008, 11:20 PM   #129 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 metro
90 day: 59.91 mpg (US)
Blue Z - '07 350Z coupe
90 day: 34.13 mpg (US)
HUFFER - '98 Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Riviera Base
90 day: 32.13 mpg (US)
Johnny, What's your vaccum @ 55 on a flat stretch road ?
How about a 1 Litre Street rod?
Old 07-19-2008, 08:11 AM   #130 (permalink)
Hi-Tech Redneck
Vacuum can vary depending on load. On a smooth road, no wind I run anywhere between 10 and 13hg normally. At idle it's at 19hg.
BTW, RacerX has hooked me up with some headlight setups and should arrive soon, so all those others who offered, thanks! RacerX was a lot closer to my area.
I will be sure to post the conversion. I knew I needed those 2 stage lights in my bumper for some reason besides "coolness".
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 37 11-06-2009 10:37 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
