Old 06-18-2008, 07:49 AM   #31 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Blue Jay - '97 Metro
90 day: 50.71 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Quite a turnaround from kicking it to polishing it lovingly
I have a Love/Hate relationship with this car
Old 06-18-2008, 09:33 AM   #32 (permalink)
akcapeco's Avatar
V-strom 650 - '07 DL-650 V-strom
90 day: 55.03 mpg (US)
07 Focus ZXW - '07 Focus ZXW SE
90 day: 34.11 mpg (US)
Mullet,
The car is looking great... it looks like those headlights would clean right up, too.
Old 06-18-2008, 12:04 PM   #33 (permalink)
Motorcycle Rider
Thumper - '08 XT250X none
90 day: 79 mpg (US)
this might be a stupid question... not sure.
since the engine is only 1.3L, would it be possible to use a motorcycle battery to turn it over? this might save you 5 pounds in weight, since they are smaller.
many motorcycles are over 1300cc's these days.
Old 06-18-2008, 12:08 PM   #34 (permalink)
Slow and easy
Josie - '87 Pickup
90 day: 31.37 mpg (US)
Man, now you have to pull the engine and paint it, too - something classic and offbeat, like Fairbanks-Morse green. That'd look appropriately strange in there.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 06-18-2008, 09:27 PM   #35 (permalink)
Hi-Tech Redneck
I tried cleaning them up even with rubbing compound and a buffer. There seems to be some coating on them that melts a little with brake cleaner, but I did not feel like trying to remove it all like that. I thought about converting to the "Sealed Beam" setup found on the 4 door and others, but then I would lose some aerodynamics. If anyone knows what I can use to melt off this old clear coating without hurting the lights or my paint/bumper, let me know.
It's actually a 1.0L engine. I think a smaller battery might be a great idea for weight reduction!
That has already crossed my mind, but I was thinking more along the lines of "Caterpillar Yellow" or "Chevy Orange". Image a painted little 1.0L with a CAT diesel powered scheme and black trim.
Man, I wish I had another Metro! I would totally finish rebuilding mine, then the other one would be next!
BTW, my exhaust went to hell, so I replaced it all! I removed the bad cat and replaced it with a scrap piece of 1 3/4" pipe all the way to the resonator and put a new muffler and donut gasket on..........
Exhaust pipe = $0.00
Donut gasket = $10.00
Walker replacement muffler = $90.00
Clamp = $2.00
Total cost = $102.00
Labor time = 3 hours
Old 06-18-2008, 09:55 PM   #36 (permalink)
dwendt1978's Avatar
Dragon - '93 Metro XFI
90 day: 51.13 mpg (US)
Damn Johnny, you've come along way on this car. Great job. You also did a slick job on the mirror delete. I'd try the driver side too. With those interior convex mirrors.
Awesome job.
Old 06-19-2008, 12:41 AM   #37 (permalink)
pontiac trans am - '00 firebird trans am
jeep 1 - '02 wrangler
90 day: 16.76 mpg (US)
jeep 2 - '07 wrangler x
90 day: 19.39 mpg (US)
Toyota - '09 Corolla lx
at auto-zone (and im assuming other autoparts stores) they have a headlight "restorer" which is basicly a super fine sanding paper and rubing compound (usually) its a bit of work but it turns out great! just a thought, i dont know if there is anything else that removes hazing
Old 06-19-2008, 12:50 AM   #38 (permalink)
Green Machine - '92 Metro XF i
Last 3: 42.66 mpg (US)
Black Ball - '99 Contour SE V6 Auto
Red Baron - '96 Civic HX
you can use nailpolish remover, which is basically watered down acetone. then get "wet or dry" 1500 or 2000 grit, wet sand the covers and work the plastic with the buffer off of the car.
The only problem is that one the uv protection in the plastic goes, the lights will not stay clear long, especially if you live in the deep south.
but they will look nice....
Old 06-19-2008, 01:35 AM   #39 (permalink)
Steady as she goes
RacerX's Avatar
Shooting Star - '95 metro
90 day: 59.91 mpg (US)
Blue Z - '07 350Z coupe
90 day: 34.13 mpg (US)
HUFFER - '98 Riviera Super Charged
90 day: 30.69 mpg (US)
Kandy, Flake-n-Flames - '96 Riviera Base
90 day: 32.13 mpg (US)
Johnny, On those headlights.....Start with 2000 grit or 1500 grit wet sanding paper. The sheets are half sheets if you go with 3m. Fold the half sheet into thirds. Find something flexible yet firm to back up the sand paper like a little rubber squeege or firm sponge. If you have a Napa or a bodyshop supply house near by they have wet sanding pads.
(this helps keep your finger tips from doing the sanding and helps sand more evenly) . Get a CLEAN bucket and fill it with CLEAN water put a LITTLE squirt of liquid dish washing soap in the bucket and mix it up a little. Rinse off the head light of any dirt and start sanding. Start at a corner and work your way across the lense. Try not to push to hard and rinse frequently. When you are sanding try to do it when it's quiet so you can hear the paper rubbing the plastic. As you are sanding if you hear a little "zing"...That is a piece of dirt between the paper and the lense STOP and rinse the paper and the lense. Sand the lense until you see that most of the imperfections on the surface are gone. The lense will still look very cloudy but you want it to look "even" not more cloudy in one spot then another. This will take some time maybe 1/2 hour or so per light. But patience is well worth it for these lights are $130.00 each (new) aftermarket. Next get a variable speed buffer (Not a 7 1/2" Grinder) with a wool pad and micro finishing compound or a compound that say's it will remove 1500 grit sand scratched. Smear up the lense with compound and buff it SLOW with moderate pressure and I mean SLOW. Take your time, As the shine comes back to the plastic you can spin the buffer a little faster. If you buff it to fast and too hard and the compound dries out you WILL burn into the lense. The lense will now have a shine and will be much clearer, Clean the pad or change your pad and now buff it with a cleaner wax or something that will remove micro finishing scratches. This will bring the "sparkle" back. Again buff it slow Buff until you are happy with it then give it a coat ot two with regular wax by hand and try to keep up with waxing them... Hope that helps .......I've been doing that for years.... Keep up the great work on your thread !!!
How about a 1 Litre Street rod?
Old 06-19-2008, 09:28 AM   #40 (permalink)
Moderator
Daox's Paseo - '97 Paseo
90 day: 67.16 mpg (US)
Daox's Prius - '04 Prius
90 day: 52.66 mpg (US)
Looking very nice Johnny!
BTW, this is what I use for foggy headlights: http://www.meguiars.com/?clear-plast...Cleaner-Polish
EcoRenovator.org - Efficient living and green home improvement
Prius Build Thread
Paseo Build Thread
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 37 11-06-2009 10:37 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
