Old 06-25-2008, 11:38 PM   #51 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
I am thinking of maybe experimenting with duct tape and find out which would give me the best results.
Old 06-25-2008, 11:50 PM   #52 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Vibe base
90 day: 38.88 mpg (US)
What type of material did you use on the front bumper of blackfly, Metro?
-Terry
My Pet Threads:
Vibe Mods and What's in a UserName? and YKYAEI
Old 06-27-2008, 05:37 PM   #53 (permalink)
akcapeco's Avatar
V-strom 650 - '07 DL-650 V-strom
90 day: 55.03 mpg (US)
07 Focus ZXW - '07 Focus ZXW SE
90 day: 30.09 mpg (US)
I'd like to do this mod also... but I'd like it to look almost imperceptible... even a clear piece of thin plexiglass would do the job.
Old 06-29-2008, 12:38 AM   #54 (permalink)
Hi-Tech Redneck
Mirror block redone
Well, my mirror cover for my right side mirror delete has flown off while heading to Yankee Lake Truck Night and when I got home, I decided to make it permanent. I made another cutout of the original cover posted on page #2 of this thread and decided to screw it to the body instead of using silicone.
I pre-drilled two holes in the metal support behind the mirror mount..........
I then used 2 black sheet metal screws to attach the plate firmly in place.......
I was going to use silicone on the cover to seal up any gaps, but after installing the cover, it looked good enough for me...........
Now I no longer have to worry about losing my mirror delete cover since a replacement will never go in it's place.
Old 06-29-2008, 12:55 AM   #55 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
3 pages and all I see is a mirror delete and some lights.
What did I miss?
Old 06-29-2008, 01:26 AM   #56 (permalink)
Hi-Tech Redneck
Vacuum/Econometer gauge
What did I miss?
This little car is driven over 100 miles per day and all repairs/mods are being done as the car is being used and as time and weather allows. Read the date on the first post and you will see I accomplished a lot in that time since starting the thread. You would know that if you read the freakin' posts to begin with..............
Engine rebuild (fuel economy related issue)
Timing advance
Complete tuneup
Air intake mod
DRL disable
Hyper-inflated tires
Antenna relocation
Transmission swap (fuel economy issue and required repair)
Mirror delete
And now a new vacuum gauge posted below. This car is pushing 65 MPG right now with simple mods and more extreme mods like the grill block and fender skirts will be posted as those come into play. Just refrain from posting if you want to be as stupid looking as your avatar Frank Lee. I am sure other people may benefit from what I have done and will do in the future. If you don't like it then too bad.
Anyway, back on topic.................
I used to have one of those really nostalgic vacuum gauges that read "Power" and "Economy", but the needle broke off and I had a hell of a time locating a replacement. The new gauge is a "Vacuum/Boost" gauge made by Sunpro, but the only scale I can use on a non-turbo vehicle will be the vacuum side of the gauge.
The new gauge required me to do a complete installation, so I decided to share it with you. The first thing I had to do is find a proper mounting location and on my car, the spot on the column was perfect for a 2" gauge. I simply used self tapping screws and secured the mount to the top half of the column cover...............
I then placed the gauge in the proper location and ran the vacuum tubing and electrical wires for the gauge illumination behind the cluster cover so nothing is exposed.
I simply removed the heater control cover plate and unplugged the bulb and spliced the illumination wires right into the harness so the gauge lights up when the cluster lights up.............
The mounting and illumination is now complete. The last thing to do is to run the vacuum hose provided with the gauge through the firewall to find a vacuum source. I ran a long screwdriver through the main wiring harness boot and fed the tubing through the gap made by the screwdriver.
I then adapted the connector to a vacuum source to monitor my fuel economy.
Here it is all installed...............
Sunpro vacuum gauge = $23.00
Total labor time = 2 hours
Old 06-29-2008, 01:58 AM   #57 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
And here I thought those were repairs.
Old 06-30-2008, 12:50 PM   #58 (permalink)
akcapeco's Avatar
Mullet, great work... Ignore the troll.
I love watching the transformation of your Metro... especially the part where it went from ugly duckling to... er... hot.
My Metro is pretty far toward the good looking end of the spectrum... I wish there were more. I don't like being perceived with the bulk of Metro's that look like they survived a demolition derby.
Old 06-30-2008, 03:45 PM   #59 (permalink)
Hi-Tech Redneck
That's true! Mine had several dents in the body, but I took the time to get them all straightened out because the paint looked so good. I was impressed with how well it cleaned up. There are very few Metros in my area and there are none that look as good as this one! I got many plans for this car and intend on posting them here as I go along. I don't have to share what I have learned and experienced with others on the internet, but I like to.
Don't worry, I wont feed the Trolls anymore............
They drag you down to their level and beat you with experience
Old 06-30-2008, 06:13 PM   #60 (permalink)
chop suey
Blue - '93 Tempo
F150 - '94 F150 XLT
Troll? LOL
With 2000 views I thought "this guy must be modding the snot outta that thing"! It's a legit question.
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 06:11 PM
Geo Metro XFI Convertible Project Finished Coyote X EcoModding Central 227 11-14-2009 11:31 PM
$10 Metro on Craigslist. Project car, anyone? MetroMPG The Lounge 6 08-31-2009 02:21 AM
New to the forum, with my RX-7 EV Project... BigMouse Fossil Fuel Free 14 02-28-2008 05:14 PM
Radical Metro Aero Mods? Coyote X Aerodynamics 8 01-01-2008 05:05 PM
