Old 11-17-2011, 02:09 PM   #1 (permalink)
multiple air dams??
has anyone ever installed an airdam in front,one in the center,and maybe one in the rear?
Old 11-17-2011, 03:06 PM   #2 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
How the concept works eludes me, especially the one in the rear.
Old 11-17-2011, 03:09 PM   #3 (permalink)
Lead-footed Econewbie
Ceffy - '97 Cefiro 25 excimo
90 day: 23.27 mpg (US)
What are you thinking the centre and rear dams will do? More air deflection? Or do you mean side skirts and rear diffuser?
Old 11-17-2011, 03:33 PM   #4 (permalink)
the concept, is for the second one to block some of the air that does not get blocked by the first airdam.the third might not even work.does this concept still elude you?
Old 11-17-2011, 03:37 PM   #5 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
A belly pan will probably work better to smooth out the airlflow. More air dams seem superfluous.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
Old 11-17-2011, 04:04 PM   #6 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Yes it does.
I can picture how they could be mounted and how they might look; that isn't the issue. The issue is, airdams (in the front anyway) work not because they are sleek, but because they direct air flow from draggy areas to less draggy areas. So for instance if I were to put one in front of the rear axle on my pickup, what exactly would it do? The "flow" under there is already a complete turbulent mess... it would shield that axle though... directing air up above, like to the floor of the box and all that nasty chassis stuff wouldn't help so a before axle dam would have to go up as far as it can? And/or be angled such that it tries to direct air down to the road? Or out to the sides?
And then there is the idea of one on the back. The very back? Where we are trying to make the wake zone smaller? I guess I can kind of imagine where trapping a rolling wave similar to why it is said that pickups are better with the gate up are better... but.... eh, I don't think the flow situation is the same down there next to the road.
Sven7 (11-18-2011)
Old 11-17-2011, 09:20 PM   #7 (permalink)
Ladogaboy - '011 Lancer EVO GSR
Team Emperor
90 day: 27.18 mpg (US)
E85 EVO - '011 Lancer EVO GSR
90 day: 21.38 mpg (US)
The only thing I could see is two "mini dams" to direct air away from the rear tires.
Old 11-18-2011, 01:29 AM   #8 (permalink)
JasonG's Avatar
1 Ton - '94 C3500
90 day: 19.7 mpg (US)
Big White Brick - '03 Express Van
90 day: 15.19 mpg (US)
Like Frank said, once the air is under there you will just be adding drag.
Now I have considered trying a sortof wedge shape cross between sideskirts and an air dam in front of my rear axle to force air out .
Support Bennelson !
I can't understand why my MPG's are so low..........
16000lb, 41' Toy Haulers are rough on FE!
Old 11-18-2011, 02:32 AM   #9 (permalink)
[QUOTE=Frank Lee;270789 So for instance if I were to put one in front of the rear axle on my pickup, what exactly would it do? The "flow" under there is already a complete turbulent mess...
[/QUOTE]I was thinking in front of the axle,before the floor curves.Ok, the rear one was a bad idea.
Old 11-18-2011, 05:12 AM   #10 (permalink)
Schwinning!
Sven7's Avatar
Team Ford
Just do Prius style air deflectors in front of the wheels and call it a day!
