Old 02-02-2010, 11:27 PM   #11 (permalink)
the power/energy going back during braking/coast i think i get ...that is a good thing rt...regen ...the alt's are meant to only keep the batteries powered properly like a regular car(gas)not to do anything else ...im sorry if i didn't explain it clearly...im still new to the green world
Old 02-02-2010, 11:35 PM   #12 (permalink)
ecomonkey
silver clown - '02 echo 2 door base
90 day: 45.48 mpg (US)
if you are not using the alternators for regen then they would be a net loss for you, you get less energy out of any device,machine than you put into it. if you want to extend the range of an electric car by making electricity to recharge a battery, then a generator making electricity running a battery charger would not over charge anything ,the battery charger would regulate that. plus all the extra weight of alternators would be hard to justify and probably reduce your range.
Old 02-02-2010, 11:55 PM   #13 (permalink)
My employer is MTX Audio, we have a pair of Escalades each with two of our Jackhammer woofers installed and 12+ kW of amplifier power driving them. The older Escalade has six, 400A Powermaster alternators installed in it like this:
But that's a show vehicle, designed to exhibit a product... efficiency is irrelevant (though the 22" Jackhammer is an efficient sub at 97dB@1W/1m)
I think overall using an engine to run 12v alternators to charge individual 12v cells in a higher voltage traction battery isn't going to be anywhere close to efficient.
2001 ZR2 Blazer e85/gas flex
Old 02-03-2010, 12:12 AM   #14 (permalink)
Thumbs up
ok im at a lose.....i worded wrong or im just not getting this..lol....the alts are for power to batt's only ... if the batt's don't have constant charge they drain rt? the alts r to keep the batteries charged...i.e. the pic....just on a hypothesis ...this seems as a simple remedy for power lose(due to battery power drain).... the weight would seem to matter in my thinking ...because each vehicle type can range from 100-/+ to 1000-/+ USING THE SAME MOTOR (ELECTRIC ) in general weight ...not the motor of course...lol (weight )....but in general the system would work like a regular gas car .....welll the alternator part of it...keeping the battery charged
Old 02-03-2010, 12:32 AM   #15 (permalink)
#1-- sweet ride
#2 im not trying to get my subs bumping and booming along with the tvs and Nintendo
#3 they consume alot more ....i need battery power
#4 efficient!!!! is not the issue(as in the main motor(the second motor is a different issue)..... its can it work ...
#5 now that i think about it...can that work in your system...with out having it using your main motor and having a separate system ?
Old 02-03-2010, 10:03 AM   #16 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
12kW at 13.8V is 870A. That's going to require some awfully large cables, terminals, and fuses. Why don't high-end audio systems go high-voltage? The same 12kW load at 120V is only 100A, a much more manageable current.
Old 02-03-2010, 12:00 PM   #17 (permalink)
Efficient is not the issue? I guess then I don't understand what end result you are looking for. Are you trying to make a gasoline powered charger for an electric car? Efficient matters at both ends, doesn't it?
We could have a 2nd gasoline engine run the alternators, sure... or a thousand treadmills, or a windmill, the alternators don't care what is spinning them or where it's located...
If you are trying to charge a series bank of batteries by using multiple 12v alternators, I think you'll find that it won't work just as straightforward as that because all the alternators will want to have a common ground, which will short your series batteries.
Indeed, and we're more than happy to sell those too
We do have several patents for 36v and 48v amplifiers, they're actually a lot easier to build because in a 12v amplifier rated higher than about 20 watts per channel it's necessary to build a DC-DC power supply that increases rail voltage to the output transistors... on a vehicle with 48v on tap you would just need noise filters to feed the rails straight off the power cable up to ~250 watts @ 4 ohms.
As it is, we have to manufacture what will actually sell to everyday people - 99.99% of whom drive 12v cars. It's a struggle to convince them that large amplifiers demand large power cables and often an alternator upgrade (what? you mean my stock 93 ford escort alternator doesn't have the reserve capacity for 2500 watts worth of amplifier?).. so, 12v is what it is.
The Following User Says Thank You to shovel For This Useful Post:
Wantingtomod (02-04-2010)
Old 02-03-2010, 02:39 PM   #18 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
They're probably running them at 16V, granted it's not much of a change, though. Keep in mind, they've probably got several amplifiers daisy-chained, rather than one huge 12kW amp, so there's a good chance that there's a normal sized wire coming from each of the alternators to a bank of batteries, and normal wiring between the batteries going to each amplifier.
Keep in mind, by normal, I mean entrance cable.
Really, though, probably something between 4g alt wire and 0 or 0/0 for the battery cables and maybe 2g for the amp power supplies.
I can't imagine the heat generated in that setup...
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 02-03-2010, 04:44 PM   #19 (permalink)
Ha! yeah.. bit of heat.
Deviating from the original topic here, the complete rundown of the older Escalade's system as it's configured today:
Because we're a manufacturer and not competing in any SPL event or whatever, we run a 14.4v electrical system and our plug-in cascade power supplies are 15v.
four TE4001D amplifiers, one per 2 ohm voice coil on two JH9922 subwoofers. Each amplifier hand selected to produce within +-1% of each other, at 2660w rms @ 2 ohms (as a rule we underrate our amplifiers, TE series are underrated by 20-25% in general)
two TE1501D amplifiers running four T8510-44 10"subwoofers, each amp is seeing a 1 ohm load and producing appx. 1700W RMS
These switching amps are about 89% thermally efficient at maximum output so for their combined 14,000w RMS output they draw a little under 16,000 watts from the battery bank at full boogie and produce a little more heat than one of those little plug-in space heaters or a good hair dryer.
The balance of the sound system (the part which is not subwoofers) is class a/b type amplifiers, two TE1004 amps, each of whose 4 bridged total channels is seeing a 2 ohm load, which means they are able to deliver a continuous 1900 watts output but at only 58% efficient they draw about 3,300 watts from the electrical system and produce almost as much heat as all the subwoofer amps combined.
That makes just a hair over 19,000 watts total, continuous system power at 14.4 volts, or 1320 amp draw, ignoring the rest of the vehicle's power systems which all are present and operate as stock (even has AC still) Since each alternator is a 400A monster custom assembled by Powermaster, they are all operating below maximum capacity to produce that power, though the engine REALLY complains about the load when it's being run at a show that can't provide us with mains power.
Power is supplied from each alternator to the bank of storage batteries and capacitors by 00ga copper cable (both poles, that much current would melt the frame if we tried to use chassis ground to carry it) and 0ga from the battery bank to each of the amplifiers, through individual fuse blocks.
For the record I didn't build any of it, Jason Planck and Craig Marsh are the craftsmen responsible for system design/layout/construction.
To maintain some semblance of topic here, the take-home from this is yes you can run multiple alternators from an engine, and yes they can connect in parallel to a bank of batteries. You just can't connect batteries in both parallel and series at the same time, like to charge from 12v alternators and run a 48v (or whatever) electric motor.
You can, however, use a 12v system to run a massive audio amplifier, which technically would make a damn fine (and uncommonly handsome) high voltage speed controller...
Old 02-04-2010, 02:33 AM   #20 (permalink)
Efficient is the issue....but not for the main engine(thats more than this thread can handle)
A gas car keeps a battery going a......
excuse me for my leap into the unknown but with a timed circuit of sort,cant you do what a car does with out shorting out the series ...' from my understanding the alternator keeps the battery at about 13+ volt' to keep it at proper level for longevity .... maybe im just beating a dead rock.....lol...(im not the brightest rock tossed into the pond....lol)...but with a circuit it seems like that would stop the problem of shorting.
i.e. ...
a home generator can accept multiple sources of power at once .....wind,sun,electric company and more...and it knows how to handle it....all in one process i believe...it just passes the correct energy to the work load or to the batteries (that are series wired i believe )and why car audio people dont have it yet i dont understand.car people from my dayz r alwys adding more batterries and alternatorsinstead of just putting in a 5 lb invertor,industy brushes and getting more than enuff power for the show off..not trying to side track but i know u can put a a regular sound system in a car and show off you sounds.....but in thought of using alternators......there has to be a way....for real world use.
dont get me wrong...please....but if u have a way to power your audio.....why not ..... omy is the turning into a audio/video mod talk
alternators, battery, charge, k.i.s., multiple
ZF ecomods a transmission: 8 spd auto, EOC-able, multiple input options, fewer parts MetroMPG EcoModding Central 5 01-02-2010 12:02 PM
GM: Chevy Volt's Cd is 0.28, Prius is 0.30 (tested in multiple tunnels), EV1 is 0.21 MetroMPG Aerodynamics 65 12-17-2009 09:38 PM
