Old 04-22-2010, 12:35 AM   #21 (permalink)
Anyone KNOW the weber 32/36's? I need to adjust the acc pump.
Old 04-22-2010, 09:30 PM   #22 (permalink)
I would say it all depends on what you want to do. I would do a compression test and determine if what you are starting with is worth putting money in, if the engine is worn a rebuild will do more for your MPG than most little stuff will.
I think unless you are going to go to a OD transmission dont change the 3 spd, its likely wide ratio and will do the job. Unless your gearing is numerically high or you got a line on cheap gears I wouldnt waste my time there either. Gearing is king if you are spending a lot of time on the highway, it does nothing for you in city stop and go.
If your carb is jettable (meaning you can find different jets to swap in) that will be by far your best bang for the buck. If you are looking to spend some money I would start with the ingition system, 1972 will be a points distributer.... garbage.
Old 04-23-2010, 08:00 AM   #23 (permalink)
1991 Metro 1.0 Auto - '91 Metro Lsi Auto
90 day: 38.87 mpg (US)
I second the 2.3 + 5 speed swap.
Old 04-25-2010, 02:18 PM   #24 (permalink)
Originally Posted by tr0n View Post
I'm wondering if anyone else here has gone through the motions of making their own older classic car more fuel efficient and what kinds of things I can do to improve mine?
thanks
I plan to do this also on my 66 Nova 194 6cyl.
Old 05-20-2010, 10:50 AM   #25 (permalink)
Project EconoPolo - '04 Polo Twist TDi
90 day: 52.46 mpg (US)
I'd love to have a car like that, but the mpg would make me cry! I've been on diesels for years and I don't think I could go back.
Old 05-21-2010, 01:56 PM   #26 (permalink)
The Ford 200CI six was my first "efficiency" project in the 70's. You can mill the head sixty thousandths. Or, you can pick up and old 170CI six head, mill it 0.060 inches and install for even more compression.
I did this. I also added a Weber 2bbl progressive carb, with small primary and larger secondary venturi. I milled off the single carb mount and brazed on a rectangular steel mount for the Weber. I fabricated all of this in a few hours. It could be done with a sawsall, a die grinder and a disc grinder.
I added a later model electronic ign, with vacuum and centrifugal advance. I think it was a Ford EecII.
I also did exhaust work, headers, transmission change etc.
I went from 21MPG or so, to 32.
Old 05-22-2010, 05:35 PM   #27 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...certainly NOT a muscle car, but I took a '72 Pinto with 1.6L (FOB) engine and 4-speed from 24 mpg to 38 mpg by:
1) 3.55 axle to 3.18 axle
2) rejetted stock Weber 1BBL carb
3) installed Ford electronic ignition & distributor from newer Fiesta (same engine)
4) from cast iron manifold to tri-Y header
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 05-22-2010, 06:38 PM   #28 (permalink)
I had a 289 '65 Mustang with 2bbl carb. The car could eak our 28 mpg at 55mph. Probably the easiest mod would be leaning out the carb with smaller jets.
Old 05-25-2010, 04:25 AM   #29 (permalink)
Red Rabbit - '02 Civic LX
90 day: 38.58 mpg (US)
How bout just copying the '76 Plymouth Feather Duster? A little aluminum here and there, an OD 4spd, no options, lean carb, V8 Exhaust, and a 2.94 rear axle. They were rated at 24 City / 36mpg highway (although that was a bit optimistic)
Old 06-13-2010, 10:25 AM   #30 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
I had a '71 while in college. I'll never miss that car. Mavericks are crap: bad visibility, etc.
Recently got rid of a '79 Fairmont with the 200-6. Changed over to a progressive carb (off of a GM 2.8 V6 as I recall) and mileage improved. Crappy car, as with any Falcon derivative (brakes and front end). Not many speed parts (see CLIFFORD), but there is some effort being expended online. I also changed over to FORD ignition box that had some benefit (high altitude?). Not much better as a car than the Maverick.
The motor is not in the same class as the Mopar Slant Six, but, as a tractor motor you can probably improve steady state mpg as with suggestions above in re tuning, etc. It is heavy compared to an only slightly heavier 302-V8 where a door is opened to MANY more possibilities to play with in re mpg.
Frankly, the best way -- probably the only way -- to get money out of this car is to make it stone-axe reliable.
I like 6's to no end. But not this one.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
News: Smart testing a 70 mpg diesel in the US in 2nd gen car MetroMPG General Efficiency Discussion 4 07-02-2009 11:51 AM
70 MPG CNG car Lazarus Fossil Fuel Free 10 03-17-2009 03:25 PM
