Old 12-09-2013, 11:18 PM   #1 (permalink)
Camry - '99 Toyota Camry
90 day: 39.84 mpg (US)
Block heater questions
I've done some googling but I'm still unsure as I've never had a car with a block heater nor have I ever installed one. Now I have a 99 Camry 4 cylinder so I'm guessing my options are few. I found this on ebay is it good? Any have experience at installing one like this do I have other options? Any help would be appreciated. Thanks btw I'm in Mississippi so it doesn't get too terribly cold
Zerostart 3100049 Freeze Plug Type Engine Block Heater 4 Cylinder Only | eBay
99 Camry
Old 12-10-2013, 12:30 AM   #2 (permalink)
HyperMileQC's Avatar
Trollinsight (Retired) - '00 Honda Insight
Gen-1 Insights
90 day: 68.06 mpg (US)
Redsight - '01 Honda Insight
Gen-1 Insights
Carole - '05 Toyota Corolla Xrs
Brise-Fer - '05 Toyota Echo
Send a message via MSN to HyperMileQC
These block heater are usually not so hard to install but it depends on the car. You should have the best results with this type of heater.
There are other options : heater pads for oil pan and transmission for example.
Trollinsight Modding Thread
2000 Honda Insight MT Silverstone Metallic #95 (CAN) 131K mi. 81.7 Lmpg
Best Tank : 100.06 MPG (US) | 120.2 MPG (Imp) | 2.35 L/100Km | 42.54 Km/L
Best commute : 130.8 MPG (US) | 157.1 MPG (Imp) | 1.8 L/100Km | 54.84 Km/L
Best Trip : 111.8 MPG (US) | 134.3 MPG (Imp) | 2.1 L/100Km | 47.53 Km/L
Old 12-10-2013, 12:52 AM   #3 (permalink)
Thanks yeah there is a clear view to the freeze plug. I'll have to check those out.
99 Camry
Old 12-10-2013, 01:10 AM   #4 (permalink)
So like this? Anyone use these with good results?
New 200 Watt 12 Volt Silicone Pad Oil Filter Heater Gasoline or Diesel Engines | eBay
99 Camry
Old 12-10-2013, 07:25 AM   #5 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
The most bang for the buck would be the freeze out plug type heater.
What the lowest temps you encounter down there?
Burn lean and prosper \\ //
Old 12-10-2013, 09:46 AM   #6 (permalink)
Sometimes it gets in the teens but I would say 30ish normally which brings me to my next question how strong of one do I need? Thanks
99 Camry
Old 12-10-2013, 10:10 AM   #7 (permalink)
I did some reading on the subject:
http://ecomodder.com/forum/showthrea...ing-25512.html
Old 12-10-2013, 10:19 AM   #8 (permalink)
I use 400w but it wouldn't hurt to go a little more. Like oil pans link says 600w would be pretty good for a 4 cylinder but 400 is enough for me. I shoot for a minimum plug in time of 1 hour but a good goal is about 2 hours.
Old 12-10-2013, 10:48 AM   #9 (permalink)
40-60-40 MPH P&G
echo-francis's Avatar
Echo-P&G - '05 Toyota Echo base
90 day: 82.76 mpg (US)
the more watts it has the better it is
if your are good at DIY you can try this
http://www.amazon.com/Kats-13150-Alu...s=block+heater
Best Tank (1557.2 Km): 2.57 LHK (91.63 MPG (US) )
Best Highway Trip (~36.8 Km): 2.16 LHK (109 MPG (US) )
Best Commute Trip avg (73.8 Km ): 2.33 LHK (101 MPG (US) )
Echo-Troll Modding Thread
I know i dont have a very good write-up
no lean-burn? no good gear ratio? p&g is the answer
MPG=1 TIME=0
