Old 03-08-2012, 12:18 PM   #11 (permalink)
skyking's Avatar
90 day: 23.82 mpg (US)
90 day: 15.1 mpg (US)
90 day: 49.05 mpg (US)
Mule - '07 Dodge Ram 3500 ST
Thanks so much for the detail pics. I have a leetle projeyct of my own......
yes I fly the thrush. Its one of the first turbine models Ayres made. You fly?
Very nice job you have. Yes, I fly a straight tail 310 (skyking) and used to fly banner tow before 9/11.
You must be back east somewhere, nobody is doing a really cool project within driving range.
2003 TDI Beetle
2002 TDI Beetle
Custom cab, auto, 3.55 gears
Old 03-08-2012, 01:07 PM   #12 (permalink)
Originally Posted by skyking View Post
Kachi, push it on up to the original front height, see what that looks like. Give the guy some headroom in the bunk.
Yea, kind of tight up there in the old bunk. Little kiddies only, no room for adults doing adult things.
Chin Spoiler:
http://forums.pelicanparts.com/off-t...effective.html
Rear Spoiler Pick Up Truck
http://forums.pelicanparts.com/off-t...xperiment.html
Roof Wing
http://ecomodder.com/forum/showthrea...1-a-19525.html
Old 03-08-2012, 04:45 PM   #13 (permalink)
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Big outside and roomy inside.
Bigger than what I would have done, but nice.
Too Complex?
Automobile 2 - Odds and Ends pictures by kach22i - Photobucket
Thanks for the input kach22i . It is easy to see that you have some good ideas. I just need more headroom in the bunk like skyking said. My old camper had 35" bunk to ceiling and that allowed a short person to sit on the edge of the bed and that is good when space is at a premium. I do like the rear pop-up idea to reduce the wake.
Got me thinkin...Thanks
Old 03-08-2012, 04:56 PM   #14 (permalink)
Re: behind the cab radii: I was thinking you'd cut those in, same as you'd do above, rather than add something on that comes ahead of the back of the cab.
Old 03-08-2012, 05:35 PM   #15 (permalink)
I'd like to offer some advice. Reading this report http://csus-dspace.calstate.edu/xmlu...pdf?sequence=1 gave me some information I think you might find useful. It's about testing pick up trucks and aerodynamic bed configurations. These are the drag coefficient figures for aerodynamic toppers simply cut at an angle downwards, instead of a suburban like back end or a pick up truck bed.
Baseline 0.3453
Traditional canopy 0.3157
5degrees 0.2957
10degrees 0.2894
12degrees 0.2892
15degrees 0.2987
18.7degrees 0.3091
Now as you can tell the 12 degree slope has the lowest drag coefficient, however it isn't much lower than at 10 degrees or 5 degrees.
This suggests to me that in this case, instead of following the template as you would do on a boat tail, you may want just a slight taper on the top and sides. Even just a few degrees. That way you end up with a fairly significant drag reduction, without impeding the usefulness and spaciousness of the topper.
If it isn't going to be a huge engineering challenge I think the pop up design would be very useful.
Whatever design you do choose I'm looking forward to seeing it all come together.
Old 03-08-2012, 05:45 PM   #16 (permalink)
90 day: 62 mpg (US)
Good point. What you suggest makes the most sense rather than dealing with hinges and fairings but i am going to put the jacks in a hollow tube "receiver" in that area so I can remove them easily for travel. The green square in the pic.Click image for larger version
Old 03-08-2012, 06:39 PM   #17 (permalink)
Can those front jacks go back 4-5", right behind the radii?
Old 03-08-2012, 07:08 PM   #18 (permalink)
90 day: 62 mpg (US)
Baseline 0.3453
5degrees 0.2957
10degrees 0.2894
12degrees 0.2892
15degrees 0.2987
18.7degrees 0.3091
Wow lots of stuff .Was not expecting such good results at 5 degrees.Thanks a lot
Old 03-08-2012, 07:19 PM   #19 (permalink)
90 day: 62 mpg (US)
Cool. Never did any banner towing. I'll watch for your areoshell thread. And yep East Coast
Old 03-13-2012, 11:44 PM   #20 (permalink)
Recreation Engineer
KamperBob's Avatar
Black Stallion - '02 Toyota Tundra 4WD xCab
Half Pint - '06 Yamaha XT225
Excellent project. I can't wait to see more. Rock on!
Recreation Engineer
The Following User Says Thank You to KamperBob For This Useful Post:
turbothrush (03-15-2012)
