Old 09-01-2009, 11:48 AM   #1 (permalink)
Baltima - '98 Altima GXE
90 day: 34.13 mpg (US)
My Altima 1998 has bad idle after started
During winter (December), it was a pain to start (it even killed my battery )
So I went to dealer (March) to clean throttle body and injectors.
Since then, it seems to start up more faster (maybe the temps are warmer)
But, the problem is when it has been started, the revs goes to 2k rpm and goes back to 1k rpm. Then it goes to 2k rpm and goes back to 1k rpm again.
At the end, it goes slowly to 2k rpm and goes back to normal.
Sometimes, it stucks at 2k (or 3k when really cold) rpm until I put it on reverse or drive.
I suspect there's a leak at the intake manifold gasket as the altimas have that problem.
What would cause this problem?
Thanks! ^^
Old 09-01-2009, 12:38 PM   #2 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 xB
90 day: 52.44 mpg (US)
0-60 in 7 seconds - '02 SE-R Spec V
90 day: 37.63 mpg (US)
A leak in the intake manifold gasket would cause that problem.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
5MT. 49.4 mpg avg over 28,860 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
Old 11-02-2009, 12:32 PM   #3 (permalink)
I got replaced the throttle body and the ECU.
It fixed the idle problem.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Review: 2008 Nissan Altima 2.5 S, CVT RH77 General Efficiency Discussion 10 03-09-2010 03:40 AM
