View Poll Results: Can take fuel economy higher without P&G?
Yes 5 50.00%
No 3 30.00%
Real men drive without engines 2 20.00%
Are you sure you didn't forget to carry a 2? 0 0%
Voters: 10. You may not vote on this poll
Old 09-26-2013, 01:57 PM   #11 (permalink)
XJ Cherokee - '00 Jeep Cherokee Sport
90 day: 12.96 mpg (US)
FoFO - '11 Ford Focus SE
90 day: 36.78 mpg (US)
Seems like the super high rear end gearing was just for EPA testing. Real world, sometimes, you need to cruise at higher than idle speed!
My Ford Taurus was happiest at 70MPH.
Old 09-26-2013, 07:51 PM   #12 (permalink)
The brake pedal is evil
Denny's Detector - '08 Mercury Grand Marquis
Taserface - '17 Chevy Volt
I'm going to clean up my cooling system. Right now (not sure if stock) the radiator can't get any static pressure because there is a gap between my AC condenser and the radiator that looks like there should be ductwork covering. I will likely end up adding more ductwork so that I can have more airflow turn into pressure for the radiator.
Getting sensor data off of a pre OBDII Toyota ECU via TDCL.
All of this is on E10: Project E is my current focus.
