Old 01-23-2009, 12:31 PM   #1 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
My car is too eager to switch to open loop
I've had my scangauge for a few weeks now, and I've noticed a few undesirable things my engine management computer does, especially when it's cold.
Most annoying is the very high idle until it warms up. I show an open loop idle, 1500 rpm, and 1gph for the first minute or two of driving. Once it gets vaguely warm, I see open loop, 1000 rpm, 0.50gph. This is still not as desirable as the closed loop, 500rpm, 0.25gph that I've come to expect. I often see the 0.50gph idle with the coolant temp at 195°F while I'm trying to pulse and glide. I run 0W30, so I'm confident it can idle lower especially while it's cold. Can I force it into closed loop idle?
There's a seperate issue: whenever I open my throttle more than, say, 1/3, it goes into open loop. Yeah, I know, welcome to the real world. Still, can I keep closed loop for slightly larger throttle aperatures? What if I mod the TPS?
Old 01-23-2009, 12:37 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Get a block heater!
Even if you're able to, you do not want to. The engine is running as it should.
Old 01-23-2009, 01:45 PM   #3 (permalink)
Left Lane Ecodriver
Sure I want to modify it. The engine management software is desperately afraid of stalling, and it's built to endure things like 10W30. I want my ECU to live on the edge a little.
This chart, from a paper by Subaru, shows my engine's BSFC (in grams of gas per horsepower-hour), which is what I need to minimize to get the most oomph out of a gallon. The chart leads to two conclusions: revs bad, using the engine near its capacity at a given RPM good. The latter is achieved with throttle.
I know the above plot represents what the engine is capable of. What I'm not sure of, is whether their test used the same ECU I have. Oh, if I only had a dyno and a laptop-based OBDII data acquisition setup.
Old 01-23-2009, 01:51 PM   #4 (permalink)
Left Lane Ecodriver
And then it occured to me: I do have a dyno, in the form of a 600' ascent at 10% grade. See how much fuel it takes to get to the top at top speed in 5th gear, repeat the test in other gears with cruise control. I'll see if I can get out to the hills this weekend.
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
Kill switch for 88-95 Honda Civic/CRX/DelSol AndrewJ DIY / How-to 36 06-27-2011 05:24 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
$500 and 30mpg car? possible? olderthanme EcoModding Central 6 07-15-2008 10:37 PM
GM's idiocy shown in small car "greenwashing" bait & switch MetroMPG General Efficiency Discussion 8 12-10-2007 03:01 AM
