Old 07-18-2017, 03:54 PM   #1 (permalink)
My Civic idles bad in neutral- Please help!
My 2005 Civic with a 4 speed automatic transmission normally idles at about 1,200 RPM in neutral while sitting still, but started this weird thing of idling at around 2,000 RPM while coasting in neutral and the idle drops as I slow down. It is not the idle air control valve, since I disabled it and it did the same thing. The other thing that I noticed is that if I jack up the front of the car and start it in neutral, the wheels spin almost as fast as if it is in D4. I think the transmission is not disengaging the engine from the wheels fully when in neutral, and the wheels are spinning the engine when coasting in neutral. Does that sound reasonable? Thanks in advance for the help!
Old 07-18-2017, 06:43 PM   #2 (permalink)
darcane's Avatar
Have you disconnected the battery recently?
7th Gen Civics have an idle learning procedure that they need to go through to reset the idle any time the battery is disconnected.
I wouldn't worry about the wheels spinning in neutral unless it is enough to move the car when it is on the ground.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
The Following User Says Thank You to darcane For This Useful Post:
Xist (09-07-2017)
Old 09-07-2017, 02:14 PM   #3 (permalink)
EcoModding flying lizard
Daschicken's Avatar
Cibbie - '88 Honda CBR 250R
Motorcycle
90 day: 48.49 mpg (US)
Rarity - '06 Honda Accord EX V6
90 day: 29.88 mpg (US)
Baby viff - '86 Honda VFR 400R
Motorcycle
90 day: 42.15 mpg (US)
Latios - '08 Suzuki SV650SF
Motorcycle
90 day: 64.56 mpg (US)
Mazda 3 - '14 Mazda 3 i Sport
90 day: 43.25 mpg (US)
A little late here, but even 1200 rpm sounds too high. Rev the car up by hand and see if you can push the throttle back even more than what the return spring will do. This sounds like a sticky throttle cable.
-Kaze o tatakaimasen-
Best trip in V6: 52.0
Best tank in V6: 46.0
Best tank in Mazda: 49.9
Best tank in CBR: 61.3
Best tank in SV: 83.9
You can lead a fashion-conscious horse to unusual-looking water...
The Following User Says Thank You to Daschicken For This Useful Post:
Xist (09-07-2017)
Old 09-07-2017, 09:43 PM   #4 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
Did they still have a throttle cable in 2004?
Old 09-08-2017, 11:39 AM   #5 (permalink)
Yep.
Old 09-09-2017, 12:31 PM   #6 (permalink)
Yes, I checked the throttle cable. The tension is correct.
