As some of you predicted I did see an increase in overall engine temperature due to the total block of the upper and lower grilles. So, I cut a hole in the center of the lower grille block and lowered the top edge of the upper grille block to allow small amounts of air to still travel into each. I'll post pics later if I can, hopefully this will return things to normal.
