Go Back   EcoModder Forum > EcoModding > The Unicorn Corral
Old 07-28-2017, 09:10 PM   #1 (permalink)
i should weld
Send a message via Skype™ to ellenor2000
Thumbs down My first and hopefully last corral entry, and it's hypothetical
Wouldn't running variable 20something:1 (basically, maximum lean running) to 11:1 (rich max) AFM with a high compression ratio, electronic spark control, diesel-type exhaust scrubbing and multiport direct injection on the late side of the compression stroke (similar to diesel) have reasonable efficiency? I mean, it's running lean, so it is burning more of the fuel and it's probably producing way too much NOx... but would it burn less fuel per horsepower at part-throttle, where the throttle would be more open for the same power level?
I realise Honda did a less extreme version of this, and probably Chrysler too.
But this seems pretty #Unicorn to me.
2002 Ford F-150 XL, rear wheel drive, with the 4.2L V6. "Seemingly low CoG" according to one of my instructors.
80s Ford Ranger 4 wheel drive, with an engine with more blowby than actual expansion. Not officially mine yet, waiting for the plough to come off. Problems: brakes cacked, front diff & axles blown, no C-diff in 4H/4L, engine is a crying child with terminal oil loss which I want to fix, frame rust.
Old 07-29-2017, 12:13 AM   #2 (permalink)
It doesn't sound totally unicorn-ish at all.
Old 07-29-2017, 03:45 PM   #3 (permalink)
...beats walking...
Old Tele man's Avatar
Lean-burn works and is VERY fuel efficient, but EPA kills it because it doesn't play-well with catalytic converters and emits too much NOx.
2014 Toyota Prius 1.8L eCVT
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2011 Chevrolet LTZ Cruze 1.4LT 6A
1971 Dodge Charger 318 3A
1970 Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 07-30-2017, 01:20 AM   #4 (permalink)
i should weld
you could still use a diesel-type exhaust system (2 way cat, and DEF system)
Old 08-01-2017, 02:02 AM   #5 (permalink)
I'd rather use water injection instead of DEF.
Old 09-01-2017, 03:19 AM   #6 (permalink)
Delivery 'Boy - '86 Suzuki Mighty Boy
90 day: 37.15 mpg (US)
SkipSwift - '13 Suzuki Swift GL
90 day: 35.44 mpg (US)
If you combined a variable compression engine that uses a sliding piston in the head (to vary compression without affecting squish clearance) with a simulated atkinson-cycle (with VTEC engagement so you could still run normal cam timing in power mode) you could reap *huge* part throttle gains.
Remember the Prius engine is around 13:1 compression right now. I'm willing to bet that the only reason it isn't 15:1 (for better efficiency on a highway cruise) is because it would ping at full power (you could close the intake valve even later, but that would reduce max power further). With a variable compression engine and atkinson-cycle you could eliminate that shortcoming.
You would always be running the highest expansion ratio possible.
But that just mixed three patents from major companies that don't want you using their tech...
Originally Posted by Crazyrabbit
In God we trust. All others: bring data
Old 09-01-2017, 06:39 PM   #7 (permalink)
i should weld
I'd like to demand data from God too, because he hasn't proven he exists yet.
Anyway... I had an even dumber idea involving the combination of a jet engine and a steam engine (using the jet engine to boil for the steam engine, and any waste exhaust, of which I hope there will be a lot, will be dumped into a recovery turbine attached to a 3 speed automatic transmission... the steamer would be run through a 5 speed manual)
I suspect the fuel economy would be horrific, and so would the emissions (NOx from turbo-steam-shaft boiler, water vapour and blowby from the steam engine crankcase, though the vapour should be fairly tame and condensable)
Old 09-01-2017, 08:48 PM   #8 (permalink)
V8 guy
Sounds like you just need a diesel engine.
Why reinvent the wheel?
Old 09-01-2017, 08:54 PM   #9 (permalink)
i should weld
because i want gasoline, i want steam, i don't want a lungful of dieselbacco smoke (though I like diesel engines, I don't like the PM1 soot in Euro 6 dzl or PM25 in noncompliant dzl)
Old 09-02-2017, 01:43 AM   #10 (permalink)
Water injection to mitigate pre-ignition associated to some extreme lean-burn would give you both the gasoline and the steam you want
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
