Old 12-30-2008, 09:43 PM   #1 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
My MPGuino Case
I figured putting the second mpguino on my dash like before was just asking for trouble till I get my door locks oiled and working so I made a pretty nice enclosure. It is using an old VHS tape box. I just cut one end off, cut a display opening and stuck it in there.
The only problem I had was I didn't know what to do with the buttons. I thought about cutting them off the board but they weren't tall enough to stick through the plastic much. I dug around my junk pile to find some old plastic button caps but ended up using some screws from an old computer case. I just drilled holes over the buttons in the plastic and put the screws in from the back side. They are right up against the buttons and the back of the case keeps the MPGuino from moving. I will probably use something else once I come across something but for now the screws work good and if they didn't have threads they would look fine. The last pic is blurry but you can see how I used the screws.
Now I just need to cover the whole thing with the same fabric the van has and it will look factory. I will probably use the other half the VHS case to make one for my Metro once I get around to ordering another kit.
My Convertible Metro XFI Plug in Hybrid Project build log
Old 01-30-2009, 02:50 AM   #2 (permalink)
That's awesome! thanks for the idea!
Old 01-30-2009, 03:59 PM   #3 (permalink)
Ziggy - '95 S6 Sedan
Manfred - '97 A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 A4 Quattro Avant
Sherman - '98 A6 Quattro Avant
Cab - '96 Cabriolet
Button Extensions
For the buttons, I cut up a plastic ball point pen refill. I cleaned out the ink, cut 3 pieces to length and used a drill bit to ream each piece so it barely fit over the button. In the end, to get a secure fit, I used an Xacto knife to make 2 small cuts in the button end of each extension. Now the extensions pop onto the buttons and fit snugly through the holes in the case. Works perfectly.
Added advantage: The refill was white plastic. The glow from the backlight illuminates the refill pieces so I have illuminated buttons. Kewl!
Old 01-30-2009, 05:11 PM   #4 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Corolla LE
90 day: 35.55 mpg (US)
I may have to steal that idea...
Old 02-12-2009, 12:07 PM   #5 (permalink)
americasfuture2k's Avatar
SLOLANE - '08 Aveo5 SV
90 day: 30.55 mpg (US)
i think you go the idea from me
D'OH!! i just saw your post date. credit is all yours man. great minds think alike
If you cant fix it with a hammer, then you have an electrical problem
http://www.cardomain.com/ride/3159589
shutup, im working on it
MPGuino release one workspace dcb OpenGauge / MPGuino FE computer 999 12-14-2011 01:18 PM
MPGuino installation/setup: 1998 Geo Metro (Pontiac Firefly) MetroMPG OpenGauge / MPGuino FE computer 12 10-11-2009 04:29 PM
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 1 10-07-2009 06:35 PM
Restricted fuel system affect mpguino readings? wagonman76 OpenGauge / MPGuino FE computer 1 09-09-2008 02:34 PM
MpGuino button covers bbjsw10 OpenGauge / MPGuino FE computer 4 09-02-2008 01:14 PM
