Old 06-02-2009, 02:33 PM   #1 (permalink)
1988 Ford Escort Pony - '88 Escort Pony
90 day: 39.88 mpg (US)
1997 Ford Escort Station Wagon - '97 Escort LX Station Wagon
90 day: 39.4 mpg (US)
Lil Red - '88 Escort GL
90 day: 32.23 mpg (US)
My new '88 Escort
Well I got my gas log started yesterday on Lil Red. It's my latest '88 Escort purchase. It has 78K original miles with a 1.9L 3 speed automatic. First tank came in at 34.597 MPG and that was without the A/C working, but I fixed it yesterday so I guess we'll see what that does to mileage. This one has an automatic instead of a 4 or 5 speed which isn't going to help mileage either. The old EPA estimate is 24 city, 30 highway, and 27 combined so it's doing much better than even the old EPA rating. New EPA rating is 21 city, 28 highway and 24 combined. First tank came in at 128.1% of old EPA rating and 144.1% of new EPA rating. So far the only mod is LRR tires at 60 PSI. Next mod will probably be a warm air intake, because that made a huge difference in my other '88 Escort. I think this tank may have gotten either very near 35 MPG or even better if I hadn't have had to let it sit and idle for 15-20 minutes while charging the A/C. Haven't even started using the A/C yet and it's already costing me.
Some of you who drive automatics give me some advice on things to do that have helped your mileage. I haven't driven an automatic much at all in the past 16 years so all suggestions would be appreciated.
Old 06-02-2009, 05:30 PM   #2 (permalink)
Slow and easy
elhigh's Avatar
Josie - '87 Pickup
90 day: 30 mpg (US)
Shift into neutral if you have to idle at a stop. That takes some load off the engine and even if you're carbureted, the idle-up control will ease off the gas for you.
You're not in front of me...
I'm 25,000 miles in front of you.
Old 06-02-2009, 10:09 PM   #3 (permalink)
Good start! For city driving, figure out where your shift points are, and try to get into at least 3rd gear whenever you can (on my Taurus, it's around 30 mph). For highway driving, try to keep as close to the speed where your highest gear engages as possible/practical (on my Taurus, that's around 43 mph). Overall, your best mileage will come from the lowest rpms in your highest gear.
Old 06-03-2009, 12:48 AM   #4 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
I agree, neutral at stops. My mpg ticks down about half as fast that way.
Learn the shift points, and many times you can coax it into high gear sooner by varying the throttle. Make sure your TV cable is in proper adjustment. Also if you have a lockup torque converter (you probably do), learn when it engages and do what you can to make sure it stays locked as much as possible, many times you can use throttle to coax it to lock sooner just like a shift.
Winter daily driver, parked most days right now
Summer daily driver
Old 06-03-2009, 12:28 PM   #5 (permalink)
the Sheetbox - '96 Aspire
90 day: 39.43 mpg (US)
don't forget to check the thing out, My car I noticed the brakes were dragging in the front, one caliper slide pin was hung up, costed me 5 mpg
"The Stone Age did not come to an end because we had a lack of stones, and the oil age will not come to an end because we have a lack of oil" ; His Excellency Sheikh Ahmed Zaki Yamani (Saudi Arabia Oil Minister from 1962 to 1986)
2002 Ford Escort Factory Service Manual For Sale Ford Man For Sale 10 06-26-2010 04:34 PM
[FS] 1987 Ford Escort 2.0 DIESEL Drivetrain 5spd Trans SE PA + EXP Project Car XFi For Sale 0 09-30-2008 03:37 PM
97 escort rsx2002 EcoModding Central 4 07-29-2008 11:39 PM
88 Prelude chimere EcoModding Central 1 07-08-2008 10:37 PM
part time paper route driver 88 civic. blindsidecustoms Introductions 5 06-14-2008 04:20 AM
