08-01-2011, 08:59 PM
5 Gears of Fury
My new favorite wheel
I must say I never bothered to check the air in my spare tire when I put my Insight on the road, so I never realized how trick the spares are in these cars!
14 x 4 inches, and the Sartorius says it weighs in at 15.1501 pounds with the tire on it. Granted the wheel and tire are for temporary use only, but I think I will still make them the next thing I try to scrounge up a set of 4 of. For off-highway, non public road use only of course! I wonder what the narrowest, tallest 14 inch tire still produced is?
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
08-01-2011, 09:15 PM
Bridgestone Potenza RE92
the 165/65 R14 is the narrowest you can get for a 14" rim, it is also only at tirerack.com in one tire, a LRR tire...
I've often wished that my commuti-car used 100mm bolt pattern instead of 4" so that I could use these rims, with it's 1,400 pound curb weight it shouldn't over load them.
08-01-2011, 10:01 PM
5 Gears of Fury
I don't know if a 15" rim would fit your commuti-car or not, but Weld Wheels used to make a 15 x 3.5" aluminum wheel in their Draglite line that had a dual bolt pattern of 4 x 4" and 4 x 4.25". If you see a 5.0L Mustang driving around with skinny front wheels odds are they are Draglites. The Mustang used a 4 x 4.25", the 4 x 4" was for Vegas etc. If you check your local Craigslist for Weld Mustang wheels you mught be able to find a few pairs cheap.
The Following User Says Thank You to War_Wagon For This Useful Post:
08-01-2011, 10:22 PM
...beats walking...
...looks like it has a designed-in "aero" cover already!
...and, school-bus yellow is a cool "see me" safety color.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
08-01-2011, 10:28 PM
5 Gears of Fury
=Old Tele man;253589...and, school-bus yellow is a cool "see me" safety color.
True, though my next super secret project car is grey, so I am thinking my buddy with the wheel polishing equipment might come in handy, strip off that yellow paint and polish the aluminum up and they would look pretty trick.
08-02-2011, 08:12 AM
The narrowest is likely the 145/80/14 Bridgestone B381 (LRR)
(VW Lupo and Audi A2 3L-versions)
I think it would run great on these.
Wider and even taller,
155/80/14 Nankang CX668 and Toyo 310
165/80/14 there's a bit of a selection, at least in Europe
08-02-2011, 03:45 PM
Could try using a motorcycle tyre?
Might not be rated for the weight, so its your own risk..
08-02-2011, 05:52 PM
#9 (permalink)
Motorcycle tires are not designed to corner without leaning so they don't have the same side wall construction, that is why if you put a side car on your motorcycle you really need to install motorcycle tires that are designed for running with a side car.
I have to wonder how much use a rim like that can handle, I know the tires are not designed for continued use and that the rim is a bit lighter but there must be standards that it still has to meet, right?
08-02-2011, 08:15 PM
#10 (permalink)
5 Gears of Fury
I would imagine that even though Honda would protect itself by saying right on the wheel that it is for temporary use only, I would have to think that a wheel made for a vehicle would have to meet all safety specifications for any wheel made that year, regardless of it's intended period of use.
