Old 10-19-2009, 03:09 AM   #21 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
...and a nut below the knuckle's mounting surface.
After all that, the bearing is still closer to the mounting surface than with a traditional tie-rod end.
You mean the bolt head below the knuckle's mounting surface?
I can't see where changing the distance from ball to knuckle surface is advantageous; when the stud or bolt is stout enough to do it all without flex- and I'd sure think they are.
Old 10-19-2009, 11:50 AM   #22 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Well, yeah, bolt head or nut, depending on what you used. It could just as well have the bolt head on top of the ball.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 5824 05-26-2012 04:25 PM
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 66 03-28-2012 08:06 AM
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 07:53 AM
Electro-hydraulic power steering question Eddles EcoModding Central 12 09-07-2009 04:47 AM
Toyota Echo power steering delete mod? zman EcoModding Central 29 05-17-2009 08:36 PM
