Old 06-22-2008, 03:19 PM   #1 (permalink)
88CRX - '88 CRX Standard DX
90 day: 32.74 mpg (US)
IS250 - '07 IS250
90 day: 25.79 mpg (US)
RX300 - '00 RX300
90 day: 18.38 mpg (US)
Myth Busters - HHO / Magnets / Carb
I'm watching a Myth Busters episode that is about gas saving devices... I'll try to see if it is on line.
I'll update, what results they get.
I watch an episode that showed drafting too last week. It works, even at 150 feet.
Old 06-22-2008, 03:29 PM   #2 (permalink)
Ratattoui - '96 Metro
90 day: 49.46 mpg (US)
Hey thanks for the heads up on this 88CRX! I just had a drafting experience which pushed my metro in the 80 MPG range so I am now a true believer. Here is an episode related to what you are referring too, if there is a more recent one, please post it!
Old 06-22-2008, 03:32 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Don't kill anyone out there with that drafting.
Old 06-22-2008, 03:38 PM   #4 (permalink)
IS250 - '07 IS250
RX300 - '00 RX300
Done in a dynometer at 35, 35...
Carburated / Fuel Injection:
Magnets: Does not work
Acetone: less efficient
300 mi carb: less efficient
They missed the point with HHO...
They shut the gas off and tried to run the car straight from HHO.
Old 06-22-2008, 03:39 PM   #5 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, were they trying to bust hho as an additive or as a fuel source?
Old 06-22-2008, 03:41 PM   #6 (permalink)
SVO, I hear ya. I stayed 1 to 2 seconds behind the rig, and was always aware of an out should an emergency arise, but I knew as long as I payed attention to the rig's speed and brake lights, I could out-stop it very easily especially at 55mph, but I was very comfortable 2 seconds behind.
Old 06-22-2008, 03:51 PM   #7 (permalink)
IS250 - '07 IS250
RX300 - '00 RX300
They just tried the Vegetable Oil in an old Benz diesel, it worked... that we knew
But, they said that it will work in every diesel car, i'm not sure about direct injected diesels. But i believe it'll mess up something after a while.
Old 06-22-2008, 04:31 PM   #8 (permalink)
'07 Saab 9-3 Sedan 2.0T S
Krieg's Avatar
Uh... all diesels are direct injected.
www.drunkenswede.blogspot.com
Running E85 in a non-flex fuel '07 Saab 9-3 2.0T
Old 06-22-2008, 05:29 PM   #9 (permalink)
I can get a noticable boost from drafting - no, let's say following a semi - and still be A) about the average spacing for California freeways; and B) farther from the truck than the truck is from the vehicle ahead (look at the shadows). Quite often (as for instance I205 around Tracy) I don't have much choice in following distance: leave what I think is reasonable room between me and the vehicle ahead, and someone will cut in. So I might as well follow a semi, since in addition to a boost in mpg, the driver's less likely to make abrupt speed/direction changes.
Old 06-22-2008, 05:40 PM   #10 (permalink)
Dartmouth 2010
SVOboy's Avatar
I just like to make sure random readers don't think we're advocating what is traditionally called drafting. I'm fine following a truck, but I won't get closer than I normally would in traffic for the sake of FE,
