Old 10-22-2009, 11:38 AM   #51 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Anyone who knows a thing or two about aerodynamics will tell you dimples do not scale up to work on a car. An 11% increase in FE at 65 mph is more or less between 15 to 20% reduction in drag, that's way too much for not having been universally accepted in the past.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 10-22-2009, 12:57 PM   #52 (permalink)
The Geo - '93 Metro
90 day: 45.16 mpg (US)
It's really embarrassing for them to go to an aerodynamic specialist and then fail this hard.
Old 10-22-2009, 01:29 PM   #53 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
They said they couldn't just beat up the car because the metal would stretch and not make a true dimple. The only way I see to duplicate it without clay would be to either mold something... or take off each body panel and make a "dimple die set" and use a press to form the dimples. Or use some thin metal, dimple it with the die set, and then attach it to the car.
The air/water flow test did show improvement with the dimples, but it didn't really look like that much. I too am skeptical about 11%. I wonder what kind of air temperature or wind differences there were between all tests.
Winter daily driver, parked most days right now
Summer daily driver
Old 10-22-2009, 02:10 PM   #54 (permalink)
igo
igo's Avatar
Blue Saturn - '98 SL1 Base
90 day: 34.67 mpg (US)
I think they did a pretty good job with the test. They even kept the clay inside the car for the final test.
I also was amazed that they made it though a whole episode without blowing anything up.
Old 10-22-2009, 03:56 PM   #55 (permalink)
Grasshopper
alohaspirit's Avatar
Makai - '01 Echo 4D Auto
90 day: 34.45 mpg (US)
Mauka - '00 Echo 4D Auto
90 day: 34.5 mpg (US)
I was a little disappointed with the results. A father test run would have revealed more. But hey gas is expensive. And they have to save money for all the ballistics gel they use.
And I think Grant "blowing up" kinda counts
Past Present Future?
Old 10-22-2009, 05:11 PM   #56 (permalink)
FWIW I worked with Mythbusters for their "will subwoofers cause an SKS to slamfire" episode (the talkative guy from MTX, Paul, used to be my boss - now I have his job and he's doing product development) - I can say from direct experience that they do not fudge results, make things up, or do any tricks to skew the outcome in any particular direction. The results you see on TV are the results of the testing which they do carry out in earnest.
2001 ZR2 Blazer e85/gas flex
Old 10-22-2009, 05:48 PM   #57 (permalink)
pgfpro's Avatar
They did a very poor test on this one and should of known better.
The amount of fuel that would be measured roughly would have been .06 lbs total and a difference of .0066lbs or 3 grams of fuel.
They needed to travel a longer distance.
Old 10-22-2009, 05:58 PM   #58 (permalink)
Everyone's a critic
Old 10-22-2009, 06:46 PM   #59 (permalink)
Moderator
If there was a small effect on the small scale car, it follows that there would be a big effect on a bigger car.
The simplest assumptions often seem the most clever ones. They are also usually wrong.
You're thinking: "How can 800 pounds of clay added to the outside of the car not change its fuel economy?" But you're thinking about it wrong. See, we're not measuring the overall real world fuel efficiency of this car. We're measuring it at very precise conditions, i.e. at 65 mph for exactly one mile. Now I grant you, but the clay on the car, it probably burnt more fuel to get up to that speed, but that doesn't concern us. We expected to see no change with the clay on, and the data bore that out.
Tire pressure didn't change, hence more rolling resistance. The car is definitely sitting lower with 800 pounds on it, hence less aero drag. But then again it's got a slightly larger frontal area. It's kind of surprising all of that evens out, but anyway.
I can see it now, all the NASCARs are gonna be looking like this. What do you think?
I think there's a reason land speed record cars do not look like this.
They like A-B only testing do they. Even the beer-liquor test was done that way.
This is also something interesting...
Old 10-22-2009, 06:50 PM   #60 (permalink)
The Commuter - '96 Corolla DX
90 day: 39.6 mpg (US)
Send a message via Skype™ to nateluke
Possibly, but judging by comments on the internet and even here, it sounds like most people wouldn't want a car that looked like that. Just like the people who think a grille block, mirror delete, etc, looks ugly, despite the real-world gains.
However I do agree with the others that there is a better solution than 850 pounds of clay. I'd drive a dimpled car any day. Kudos to the Mythbusters for testing something useful in a controlled way. Maybe we should get on their message board and suggest they do a full-tank test, or something to that effect for more/better results?
