Old 11-01-2009, 11:44 PM   #21 (permalink)
PSmodder lurker
botsapper's Avatar
Generous radius on bodywork
The 250 'Redheads' Testa Rossa by Scaglietti was also called the 'pontoon' TRs because of aft portion of the front wheel wells are smoothly blended into the body sides. The intended function was to promote faster air flow through the front brakes and better engine cooling. But Ferrari quickly designed away from this controversial design. It's interesting to compare the aero numbers of the Scaglietti 'pontoon' design compared to the later 'conventional' Pinninfarina TR designs.
http://www.allsportauto.com/photoaut...50_tr_01_m.jpg
Earlier this year this particular TR model brought the new world record for the most expensive motor car to be sold at auction. The 1957 Ferrari 250 TR, chassis 0714TR was sold for Euro 9,020,000.
http://www.ausmotive.com/images/Ferr...a-Rossa-01.jpg
Old 11-02-2009, 01:20 AM   #22 (permalink)
Errr...why not do it the way race cars do it? Vent upwards.
Instead of placing a bunch of vents on top of the fender, a budget modder could cut some vent holes in the strut towers (slightly Swiss Cheesed), seal the area from underhood pressure, and then vent though the edges of a raised hood.
Things needed...
1. Drill
2. Cardboard
3. Spacer washers and longer bolts
Front Wheel Skirts on LA Metro Bus cfg83 Aerodynamics 8 09-06-2009 05:59 PM
Front Wheel Skirts; 1950 Nash Ambassador Rokeby Aerodynamics 11 08-25-2009 10:30 PM
Dual Fuel, electric rear wheel drive, gasoline front wheel drive bucknmusky DIY / How-to 36 07-15-2009 10:45 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 18 06-07-2009 12:14 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
