Old 03-04-2009, 02:23 PM   #1 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
Neat general use heat sensor ~ AD22105
http://www.analog.com/static/importe...ts/AD22105.pdf
* User-Programmable Temperature Setpoint
* 2.0°C Setpoint Accuracy
* 4.0°C Preset Hysteresis
* Wide Supply Range
(+2.7 Vdc to +7.0 Vdc)
* Wide Temperature Range
(- 40°C to +150°C)
It can output a ground to drive a relay driver (or solid state relay) when the
pre-set is hit. Nice for fans, pumps & etc.
With a high limit of 300F, these might be useful on car radiators too.
Use them to limit charge current if batteries get too hot.?.
I might use these in a simple home monitoring system I want to build.
Just an display panel in the kitchen that would show if the temperatures
of the heating boiler, basement or outdoors went out of normal ranges.
Two chips on the boiler could be pre-set for the max and min limits.
I was also thinking about using them with the TTL I/O of a small micro controller that would signal me with an alarm and send me the status
using a simple beeper.. Using Morse code of all things.
Cheers,
Rich
Old 03-05-2009, 05:55 PM   #2 (permalink)
naturalextraction
naturalextraction's Avatar
That I can use! Thanks for the posting.
Wood stove radiant heat!??! bennelson Saving@Home 28 07-29-2010 12:39 PM
Mini-split ductless question.. Xringer Saving@Home 50 05-25-2010 05:01 PM
Electric car heat! Liquid? bennelson Fossil Fuel Free 38 12-11-2009 11:59 AM
Heat Pump Temp Lockout Settings to Gas Backup RH77 Saving@Home 0 10-25-2008 01:09 PM
Fun with Voltage Controller Heatsinks Dradus Fossil Fuel Free 14 05-02-2008 04:16 PM
