Old 07-27-2008, 11:28 AM   #1 (permalink)
FastPlastic's Avatar
98 Cherokee - '98 Jeep Cherokee
90 day: 17.18 mpg (US)
ZX7R Ninja - '99 Kawasaki ZX7R Ninja
90 day: 42.45 mpg (US)
ScanGauge TPS spike
Picked up a ScanGauge II the other day. After getting it all setup I noticed some odd readings coming from it. The TPS readout at idle spikes to 16 for a half second every now and then. Idle on my Jeep Cherokee has always been just a little ruff. Is it just an error in the readout? or is that whats affecting my idle? I replaced the TPS about a year ago so what else would cause the spike?
I found out the jeep has fuel cutoff for coasting. But it will only do it for a split second, guessing whatever is causing this is preventing it from doing it for an extended period of time.
Any help would be greatly appreciated. Thanks
Adjusted for my driving habits. 80%city/20%Highway.
20mpg city/30mpg highway or bust! Check out my mods so far
Old 07-27-2008, 12:18 PM   #2 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
The fuel cutoff reporting isn't bullet proof on the SG. It's a known issue.
On my car, looking at the "Loop" status is more reliable (goes into open loop under fuel cut).
Don't know anything about the TPS issue.
Old 07-27-2008, 04:05 PM   #3 (permalink)
Red
Red's Avatar
The TPS on the 4.0 is junk. It just getting dirty again. Mines been that way for about a year now no biggie. Sometimes spraying the TB blade and TPS shaft with some TB cleaner helps.
Just some quick info on Scangauge vs. MPGuino NoCO2 OpenGauge / MPGuino FE computer 4 06-01-2015 04:58 PM
Scangauge II vs cruise control rjacob Instrumentation 10 06-02-2011 02:36 PM
Scangauge 1 - Some help please! jdubbs_scort Instrumentation 6 06-17-2008 03:26 PM
Question regarding Scangauge MPG readout & DIY device Gregte DIY / How-to 5 05-19-2008 04:58 PM
scangauge coolant temp accuracy? Daox Instrumentation 12 05-03-2008 01:09 PM
