Need help from "the electronics guys"
My Toyota Matrix has hall effect VSS that gives the ECM a digital signal. What sort of circuit/chip will I need to take this 0/1 frequency and turn it into an analog voltage that changes with vehicle speed for my specific use? I need an analog vehicle speed signal for my torque convertor lockup bypass device.
If I can't get this to work, I may steal a signal from an ABS wheel sensor (AC) and rectify it to get a voltage that changes with vehicle speed.
Thanks in advance.
James
