Old 11-24-2011, 03:44 PM   #1 (permalink)
Need help. MPGuino GPH jumps around.
I built an MPGuino and I'm having some problems with it.
I got everything working fine except that when I put it in the car the GPH is all over the place. It will bounce to 0.07 to 10.00 or more. Any ideas on what would cause this?
Old 11-25-2011, 05:03 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
loose/shorting connection? Wrong connection/circuit? You tried to install it on a lear jet?
what value resistors did you use next to the zeners? And did you use 5 volt zeners?
Old 11-25-2011, 06:39 AM   #3 (permalink)
All secure connections. All hooked into the correct location. Tried Honda Civic VX ( intended car ) and my Honda Insight.
I tried both 50k and 100k resistors. Both zener diodes are 5.1v.
I've also even changed out the Arduino board but get the same result.
Old 11-25-2011, 11:14 AM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
Dunno, there is a 94 VX that someone added to the table of car settings, so the circuit and program as described should work. What cpu do you have on your duino?
MPGuino - EcoModder
Old 11-25-2011, 11:19 AM   #5 (permalink)
Using an Arduino Duemilanove (clone) which uses the ATmega328 running at 16mhz.
Old 11-25-2011, 11:38 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
what version of arduino? What source code (link)? What schematic (link)?
Old 11-25-2011, 11:44 AM   #7 (permalink)
Using version 0022 of the software. Tried using the stock 0.75 version of the MPGuino source that is on the wiki and I also intergrated the save data code in a seprate source. Both give same results. I'm using the arduino schmatic that is on the wiki.
Old 11-25-2011, 01:29 PM   #8 (permalink)
I'll try to post the serial data later tonight. I have not looked at it when in the car. Maybe it will tell us somthing.
Old 11-25-2011, 01:55 PM   #9 (permalink)
dcb
needs more cowbell
dcb's Avatar
you might try the cpp file instead, and without making any modifications first.
http://opengauge.googlecode.com/svn/...no/mpguino.cpp I only tried it once from arduino. You might also try version 11 of arduino like the pde file says.
Old 11-25-2011, 02:03 PM   #10 (permalink)
With the cpp file wont I have to program it with the ISP header? Never done that before. I think I have the nessary equipment to make the cable if needed.
I'll try version 11. I thought it was just so it could fit on the atmega128. I'll try anyway.
