Old 05-30-2013, 04:26 PM   #11 (permalink)
u6 goes from .01 to .06 vdc 0-100% throttle :/
Old 05-30-2013, 04:30 PM   #12 (permalink)
r12 goes from zero to about 4.5v
Old 05-30-2013, 04:32 PM   #13 (permalink)
pretty intense heat coming from dc-dc!!
Old 05-30-2013, 05:50 PM   #14 (permalink)
PaulH
MPaulHolmes's Avatar
At least the pwm signal is coming out of the microcontroller. Do you mean the CINCON is getting really hot?
Now check each side of R15 to ground (use the back of U1 for ground. It's nice and easy to access).
-Paul
kits and boards
Old 05-30-2013, 06:03 PM   #15 (permalink)
yes the cincon is i would go asfar to say as unusually hot! like very uncomfortable to keep a finger on it! and ok thats a good start r15 to back of u1 is 4.96/4.97 on the other side at 0% throttle. at 90% throttle 4.9/0.28v on the other side
The Following User Says Thank You to pbmartin14 For This Useful Post:
MPaulHolmes (05-30-2013)
Old 05-30-2013, 09:49 PM   #16 (permalink)
PaulH
I don't know if you realize it, but you are sort of hilarious! "yes the cincon is i would go asfar to say as unusually hot!" lol. Is it putting out 12v? (the cincon)
kits and boards
Old 06-01-2013, 03:06 PM   #17 (permalink)
haha i try and keep it lively , so it was confusing to get the output but the only voltage i could get was on one side of the output for 3.5v (10.9 in) did the cincon fail me
Old 06-01-2013, 03:07 PM   #18 (permalink)
since theres 2 rows of 2 on input side, and 2rows of 3 on the output i just had trouble but im pretty sure the only voltage i couldve got was about 3.4-3.6
Old 06-01-2013, 04:15 PM   #19 (permalink)
PaulH
aha! OK, the 2 rows of 3 on the output, right! One of the rows of 3 pins aren't connected to anything. The other row of 3 pins is where all the output stuff is. The pin closest to the edge is +12v out. The middle pin doesn't do anything, and the pin closest to middle is ground.
|...............o o o...| <-- PIN CLOSEST TO THIS WRITING is +12v.
those retarded dots are required for some reason. haha
kits and boards
Old 06-01-2013, 04:19 PM   #20 (permalink)
you sir are outmost helpful and kind! thank you!
