Old 07-16-2009, 02:27 PM   #11 (permalink)
Replacing the o2 sensor just because the vehicle is reporting lean and subsequently enriching is silly, there are a dozen different problems that could cause this condition and just replacing the sensor that reports the condition is literally "shooting the messenger"
The post-cat o2 sensor really, genuinely, no-myth-about-it is not used for fuel trim. Period. In fact it CAN'T be used for fuel trim. Think about it: there's a frickin catalyst right before the sensor, how would the sensor know whether o2 readings are skewed by the effectivenes of the catalyst at that moment?
Replace your fuel filter first, it needs it anyway by 30k miles. See if that corrects the problem. Then use a fuel pressure gauge on the port that exists for that very reason to diagnose the problem rather than just randomly throwing expensive parts at the problem in hopes of accidentally curing it.
Old 07-18-2009, 12:00 PM   #12 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Expensive parts? my o2 was like 40 bucks.
I'm not talking about the post cat sensor. I'm talking about the pre cat sensor. And you don't have to replace it, you just do a test, and if it tests bad, you replace the sensor, if it tests good, then you look elsewhere.
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 07-19-2009, 09:39 AM   #13 (permalink)
rusty - '00 mustang coupe
90 day: 24.31 mpg (US)
cbr929 - '00 cbr929 fast
90 day: 39.54 mpg (US)
Porshe - '06 zx10r
90 day: 37.84 mpg (US)
check for vacuum leaks and evap system, either one will cause similar problems that you are seeing. One more thing, do you have an exhaust leak by any chance? that would do it too, even the smallest one.
Keep A/C from running when you don't need it. TeamCF EcoModding Central 13 04-06-2009 01:55 PM
A Running Log website similar to EcoModder? 1337 Off-Topic Tech 2 03-12-2009 05:28 AM
Running on Air braddd Fossil Fuel Free 9 11-14-2008 12:48 AM
Just bought a '90 Metro XFi, have questions... ohmycivic EcoModding Central 29 10-13-2008 10:55 PM
Metro Running Light Mods!?!? bennelson EcoModding Central 7 08-14-2008 10:10 PM
