Old 04-20-2008, 02:04 PM   #1 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.02 mpg (US)
IMA - '010 Insight EX
90 day: 45.43 mpg (US)
Tessie - '06 TSX Base
90 day: 28.83 mpg (US)
Exclamation Need Timing Help
I followed the standard procedure for Honda timing advancement:
Warmed up until the fan kicks-on
Shut down
Jumped the Timing-ECU Isolation (paper-clip trick)
Started Up
Rotated the Distrib counter-clockwise until until I could hear knock
But I didn't hear any knock. All 3 bolt points were in their furthest position. I even tried full clockwise in case my info was incorrect. I placed it in full advance, shut down, removed the clip/jumper, and went for a drive.
IAT = 110F, Coolant = 200F
Full throttle to 7250 RPM -- no knock. I've heard it before in similar instances when the IATs were out of control.
The car does not have a knock sensor and IGN on the SG is acting normally.
Tried a low-RPM, hi-load situation. No knock. A/C on. No knock. Tried a variety of high load situations.
Do I just leave it and expect a bump in FE?
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Timing Adjustments...Worth it? HotRod EcoModding Central 5 03-08-2008 11:29 AM
Accord Timing Belt Who Off-Topic Tech 9 02-29-2008 11:39 AM
Beaver's Metro: is it running too rough? MetroMPG Off-Topic Tech 16 02-02-2008 09:54 PM
