Go Back   EcoModder Forum > AltModding > Saving@Home
Old 12-13-2016, 04:22 PM   #11 (permalink)
You can use led motion detector night lights with rechargeable batteries, the initial battery and the charger will cost you less expensive than turning on most lights when waking in the middle of the night. You can use spot lights or place recessed lights outside on motion sensors.
