Old 02-13-2010, 07:17 PM   #1 (permalink)
JonnyG's Avatar
97RAV - '97 RAV4
90 day: 22.97 mpg (US)
Neutral Coasting 4X4
My car is full time four wheel drive and I've read that it is bad to coast in neutral with an automatic. The owner's manual doesn't say anything about it. I've done it at speeds up to 25mph and it re-engages into drive silky smooth. So should I not do it or what? Unfortunately, I don't really understand automatic transmissions.
Old 02-13-2010, 10:12 PM   #2 (permalink)
Neddy Seagoon
TRD Vibe - '09 Vibe
Coasting a 4x4?
I would say as long as the engine is still running while coasting you should be ok, the engine will keep the oil pump in the transmission turning over. Also look in the hand book to see if you can tow it with the engine off, if you can then that is a good thing as you will not damage the transmission.
Good luck, Neddy.
Old 02-13-2010, 10:14 PM   #3 (permalink)
surly teady bear
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
What does your owners manual say about flat towing?
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 02-14-2010, 12:05 PM   #4 (permalink)
JonnyG's Avatar
97RAV - '97 RAV4
The owner's manual shows a picture of the various ways to tow 4X4, however, none of them show the tires touching the ground. The owner's manual goes on to say that four wheel drive models must use a towing dolly under the wheels not lifted up by the tow truck. So I'm guessing this means no coasting in neutral?
Old 02-14-2010, 01:26 PM   #5 (permalink)
Driving the TurboWeasel
If you keep the engine running there's no damage to the transmission. The engine feeds a pump that sloshes ATF around while the engine is on.
I think they don't want you to have the vehicle rolling while the engine is off and in N.
2012 Chevrolet Cruze Eco 6MT
Old 02-14-2010, 02:27 PM   #6 (permalink)
99metro's Avatar
putt-putt - '99 Metro Base
90 day: 54.44 mpg (US)
Dusty - '89 Bronco XLT
90 day: 14.62 mpg (US)
Cowboy - '90 Bronco XLT
90 day: 17.42 mpg (US)
HayHauler - '06 3500 ST
90 day: 14.07 mpg (US)
I agree with 99LeCouch. Leave the motor running and it's ok to coast in neutral. Flat towing with the engine off and neutral coasting with the engine running are two different animals.
2006 3500 Dodge QC/FB 5.9 handshaker
Old 02-15-2010, 01:29 PM   #7 (permalink)
JonnyG's Avatar
97RAV - '97 RAV4
It still just doesn't seem right to do it with an automatic transmission. Everything I read online says that it's harmful to the tranny. I guess I'll just have to do a manual transmission conversion
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 11:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 02:28 PM
Coasting in Neutral... what if you can't come to a full stop after? Sean T. Hypermiling / EcoDriver's Ed 16 10-08-2008 01:11 PM
EV Mode Coasting - go to Neutral? cephraim General Efficiency Discussion 0 08-29-2008 11:21 AM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 04:49 PM
