Old 04-08-2017, 12:49 AM   #11 (permalink)
Growin a stash
I disagree on the Scangauge. I don't think it's helpful. The Cruze already has a good, nearly instantaneous mpg display that's probably accurate +/-10%, plus stats on how much power the AC is using, etc.
2015 Nissan Leaf S
Old 04-10-2017, 07:57 AM   #12 (permalink)
Rat Racer
Fat Charlie's Avatar
90 day: 42.9 mpg (US)
Instantaneous is meaningless without short trip and long trip.
I'm also a big fan of real coolant temp numbers, not just cold, okay and too hot.
Transmission type Efficiency
The Following 2 Users Say Thank You to Fat Charlie For This Useful Post:
Daschicken (08-24-2017), Xist (04-21-2017)
Old 04-10-2017, 09:44 AM   #13 (permalink)
Kristin's Impala FFV - '10 Chevy Impala LT
90 day: 25.5 mpg (US)
XFE Coupe - '09 Chevy Cobalt XFE
90 day: 37.16 mpg (US)
Kt's Cobalt - '10 Chevy Cobalt LT
90 day: 27 mpg (US)
Penny's Rogue - '15 Nissan Rogue SL AWD
90 day: 25.02 mpg (US)
Cam's Rogue - '11 Nissan Rogue SV AWD
90 day: 24.7 mpg (US)
Cobalt, Impala & I think Cruzes have digital water temp as well. Only one average resettable average. I don't see a need for one (SG2) in my Cobalt either, I've had it hooked up but just looking at other stuff. LTFT, timing, intake air temp, etc.... SG2's don't work with different ethanol content's(without recalibration) the factory gauge does.
Old 04-10-2017, 09:47 AM   #14 (permalink)
Rat Racer
Awesome to see factories giving real numbers on their instruments!
Even if it's just sometimes.
Old 04-10-2017, 01:23 PM   #15 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
If he had a base with a manual xmsn he would already be getting 40+
Old 04-10-2017, 08:09 PM   #16 (permalink)
oldtamiyaphile's Avatar
UFI - '12 Fiat 500 Twinair
Team Turbocharged!
90 day: 43.3 mpg (US)
Jeep - '05 Jeep Wrangler Renegade
90 day: 18.09 mpg (US)
R32 - '89 Nissan Skyline
STiG - '16 Renault Trafic 140dCi Energy
90 day: 34.87 mpg (US)
Prius - '05 Toyota Prius
90 day: 50.25 mpg (US)
Premodded - '49 Ford Freighter
90 day: 13.48 mpg (US)
F-117 - '10 Proton Arena GLSi
Pickups
90 day: 36.41 mpg (US)
All new cars do this, but the critical parameter 'engine load' is always missing. Even if you have a car that gives you points/ stars as you drive, they're always set too conservatively.
Plus the auto resetting short trip is worth it's weight in gold.
Old 04-19-2017, 04:10 PM   #17 (permalink)
JSH
City Slicker - '16 Chevy Spark EV
90 day: 128.34 mpg (US)
Road Tripper - '09 Toyota Prius Package 6
90 day: 46.95 mpg (US)
Last 3: 19.56 mpg (US)
I would look at wheels / tires and grill block
Tires: Going from Low Rolling Resistance tires (Bridgestone Ecopia EP422185/65R15) to regular all-season tires (Bridgestone Turanza Serenity Plus195/65R15) dropped the mileage on both of my 2nd gen Prius 10% from 49 mpg down to 44 mpg. That is a slightly wider and heavier tire. I did it to increase the grip and handling which improved noticeably.
You could do the opposite and go to a LLR tire that is narrower and lighter. Handling will suffer but fuel mileage will increase.
Lighter wheels will also help especially around town in stop and go traffic where you are repeatedly accelerating.
The grill block should give you a couple of percentage improvement and will be more noticeable in the winter when the engine will come up to temperature faster and retain heat better. (Engines run a richer tune when heating up)
I would stay away from chips and engine tuning. Any gains you get in fuel economy are likely going to increase emissions. That is not only illegal but it will also void your warranty.
Old 04-20-2017, 09:27 AM   #18 (permalink)
divedaddy03's Avatar
Send a message via Skype™ to divedaddy03
Well....believe it or not, less than 3 weeks after I purchased this vehicle (< 1,400 mi), a trucked pulled out in front of me...and I totaled it!
If I can figure out how to upload pics...I'll share.
That said, OnStar was AWESOME....and the airbags worked flawlessly...allowing me to get out, and walk away with only minor bruises, cuts, and scrapes.
Should I consider replacing it with an Eco-Diesel or go back with a 1.4T?
An Idea:Open Source Hybrid/Hybrid Electric Car Project
Your mind is like a parachute, it only works when it's open.
Old 04-20-2017, 10:45 AM   #19 (permalink)
Rat Racer
Congrats on coming through it safely.
Back when I was looking at the Sonic, there was a decent trim level available with a manual and a small NA engine. I'm not digging into today's lineup, but with a focus on economy, I'd prefer to stay away from automatics, turbos and diesels.
Old 04-20-2017, 04:47 PM   #20 (permalink)
rmay635703's Avatar
I would go for a manual transmission Cruze hatch , turbo not required.
Otherwise the sedan will be getting a different manual transmission diesel trim.
2017 Chevrolet Cruze manual gets 52 mpg highway, 30 mpg city
I would never buy a Cruze with an autotragic
The Following User Says Thank You to rmay635703 For This Useful Post:
chevrolet, chevy, cruze, turbo
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
