Old 08-31-2009, 12:34 PM   #1 (permalink)
Little Blue - '98 Escort ZX2 Cool
Team ZX2
90 day: 46.69 mpg (US)
Big Red - '00 Excursion XLT
90 day: 15.53 mpg (US)
New Accessory Pulley = Better MPG?
So my Accesory pulleys were makeing a racket, during their replacement I saw the timing belt pulleys were almost dead. Replaced them all and now the motor is much quieter. Anyhow, drving in to work this morning I noticed my SG was reporting a lower GPH than normal on the coasts, around 17 when it is normally around 20. My normal Idle GPH is around 17-18. By the time I got to work I was seeing the idle GPH around 12-13. I'm sure the savings is very small, but the old pulleys must have had quite a bit of friction in the those worn out bearings. I also did about 1mpg better on the way to work, however that is well within the normal variation due to traffic. We'll see if it's a consitant gain. I'm just amazed at the difference in GPH...
Old 08-31-2009, 12:40 PM   #2 (permalink)
Pokémoderator
cfg83's Avatar
1999 Saturn SW2 - '99 SW2 Wagon
Team Saturn
90 day: 43.05 mpg (US)
Tygen1 -
Yes, please document your results. I assume the old pulleys were worn out OEMs. Are the new pulleys replacement OEMs or ?!?!?
CarloSW2
American Solar Energy Society
Old 08-31-2009, 08:56 PM   #3 (permalink)
Team ZX2
The old pulleys appear to be OEM, the replacements are Autozone Duralast (Korean). I'm not to pickey on that sort of stuff, the OEMs for this motor are German, but last just as long as the cheaper stuff, they need to be changed with the belt. The old pulleys were all in pretty bad shape.
I wish I could thourghly document this, but I didn't expect such a big change, so I don't have a reliable base line, just observations. The commute back home showed the same results. Runs smooth and quiet now. The Coasting GPH went as low as 0.14, just amazing to me because it never went below 0.17 before...
Old 08-31-2009, 09:21 PM   #4 (permalink)
You could get even more of a savings if you use an underdrive pulley.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
Old 08-31-2009, 09:35 PM   #5 (permalink)
toyota corolla - '99 corolla ce
90 day: 38.97 mpg (US)
i dont think its good for me , i have a sound system that can take more than 25 amp ...
underdrive alternator and all accesory is not for me I think . but its a great item !
graphic:http://ecomodder.com/forum/em-fuel-l...vehicleid=3083
lowered -1.5 inch .
+80 pound (approximation) of audio (and draw a max of 20-25 amp approx..)(ouch for alternator !!)
Old 08-31-2009, 11:57 PM   #6 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Of course it would take less fuel, you're seeing (apparently much) less parasitic losses, thus less load at idle.
"żʞɐǝɹɟ ɐ ǝɹ,noʎ uǝɥʍ 'ʇı ʇ,usı 'ʎlǝuol s,ʇı"
Old 09-01-2009, 01:08 PM   #7 (permalink)
Team ZX2
Yep, I didn't think the load from worn bearings was that great, I was wrong...
I do have a UDP, 40%, and a 30% ODP for the Alt to get it back up to speed. UDP was a minimal, probably not calcuable savings, but the motor runs smoother and rev's more freely.
Old 09-01-2009, 01:09 PM   #8 (permalink)
Team ZX2
Also, hit 50mpg on the commute to work today! That is a first Definatly something going on here...
Old 09-02-2009, 07:08 PM   #9 (permalink)
Switch to a hybrid digital amplifier to reduce the power usage.
Amanda Harris: the Prius of home audio - EcoRenovator
Old 09-02-2009, 09:15 PM   #10 (permalink)
pretty cool but too late
my eco stop there when its time to turn up the volume ...
im 16 so you can understand that I love party music and my subwoofer also
lowered -1.5 inch .
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
free OBD2 software with MPG calc whitewiz Instrumentation 6 02-18-2012 11:31 AM
How to get instant fuel consumption from Megasquirt TELVM Instrumentation 11 08-29-2011 02:47 PM
mpguino acted up today, lost mpg during fuel cut wagonman76 OpenGauge / MPGuino FE computer 9 06-17-2009 12:25 PM
Crankshaft pulley bolt blues Twerp Off-Topic Tech 18 11-03-2008 11:58 PM
