Old 08-03-2009, 08:32 PM   #1 (permalink)
New Dodge Ram's forward leaning grill
You'd think it would create more drag than a rearward sloping grill, but it apparently doesn't.
Style and aesthetics started to give way to practical considerations, like aerodynamics. "We don’t concern ourselves with aero too much when we’re doing theme searching. The thing that concerned senior management most was the grille. I wanted the cant-forward grille but management looked at it and thought it wouldn't work. So we went and built a second version with the grille leaning back but it didn't make a difference (in aerodynamics).
By the time we were done we beat the aerodynamic stretch goal for (the new Ram),"
PickupTruck.com - Ram Tough Choices: Other Designs Chrysler Considered for the 2009 Dodge Ram
Why is this?? I can think of a few possibilities:
1) The crossbar and surround are so thick that even with a rearward-cant grill, they don't smoothly channel air up and over the hood
2) The angle could force more air through the grill. Forcing oncoming air into the engine compartment and out the bottom could create the same drag as throwing turbulent air up over the hood and windshield
3) The angle of the grill, combined with the bumper right below it, funnels air to the sides, past the curved headlights, and along the sides of the truck, with attached flow the whole way
Also, I'm surprised aerodynamics were even a consideration. I'd expect the senior management to care about looks first, and fuel economy second, because presumably a 1mpg difference isn't going to influence sales that much but looking macho vs girly would.
Old 08-03-2009, 08:36 PM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
I would assume the over the top aero is so bad it doesn't matter if it goes underneath instead. *shrug*
Old 08-04-2009, 01:09 AM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Are we gonna do the blunt front end aero thing again???
A big "bubble" gets pushed in front of vehicles. As long as flow is attached at the front/sides/top transition, it's all good.
^P.S. That's a gross oversimplification that ignores underhood airflow, but otherwise I'll stand by it.
Old 08-04-2009, 02:10 AM   #4 (permalink)
QuickLTD's Avatar
Flying Brick - '96 Bonneville SE
90 day: 23.57 mpg (US)
Send a message via AIM to QuickLTD Send a message via Yahoo to QuickLTD
The eye can be decieving.. Look at all the swoopy European sports cars from the early 60's and the streamliners from the 30's with th CD of a brick. That truck probably has better aero than most of those old cars.
1996 Pontiac Bonneville SE 3.8L V6
Old 08-04-2009, 02:27 AM   #5 (permalink)
vectra a - '95 Vectra GLS
90 day: 37.51 mpg (US)
i think the important thing is the curvature above and beside the grill and how open the grill really is (some grills are partly blocked and some have better internal ducting than others) also the tip of the hood isn't the most forward part of the car, the bumper is. is you fill the void between the bumper and the hood with a high pressure bubble (easiest to spot in the concept sketch) you'll get an almost round shape.
once certain things like the size of a grill is determined by either function or fashion it's all about small details... tweaking certain angles and curves
Old 08-04-2009, 05:49 PM   #6 (permalink)
This isn't a case of blunt vs pointy, but blunt and sloped back vs blunt and sloped forward... With the added factor of a bumper below the grill helping form a kind of concave parachute shape, at least when viewed from the side.
Seems like the high pressure bubble lunarhighway is talking about within the V profile is very different from the bubble in front of a blunt convex nose.
Old 08-05-2009, 01:47 AM   #7 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 31.91 mpg (US)
Chewie - '03 Prius
90 day: 57 mpg (US)
Ooooh! forward leaning grill.... how.... forward of them.
Really, this just smells of aerowashing. The sketch looks all dynamic but the lines are lost lost once you get to the actual vehicle. Looks like any other truck to me.
What's the comparison? Since we don't have a Cd before and after, there is no way to tell if it's better or not. All they seem to say is it's no worse than before.
What is the new Cd?
Old 08-05-2009, 01:58 AM   #8 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Considering the size of the grille opening, I don't think the slightly forward-leaning grille actually would make a difference, other than slightly raising the stagnation point.
Opinion, obviously, but those trucks tend to have enough room under the hood for a small child to stand in there and wrench on it... there is probably more air going through the grille opening than under it, which means that the forward leaning grille is probably a drop in the bucket compared to the grille.
Old 08-05-2009, 03:52 AM   #9 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
In car aerodynamics the rear end is where it's at. Any time you see a car company bragging about the front and ignoring the rear they are BS-ing you.
That says it all, really.
Is this a post bail-out quote?
Old 08-05-2009, 04:12 AM   #10 (permalink)
marcusmodder
orange4boy's Avatar
Chewie - '03 Prius
90 day: 57 mpg (US)
After all my snarking, I found this: It may be an improvement over the 2008 model but the fact that one of the new models does the 1/4 mile in 14.4 seconds speaks to the main priorities: more power, lip service to efficiency. The new "improved" Ram has worse aero than the original 1994 version!
The cooperative application of aerodynamic science and innovative styling led to aerodynamic improvements on the new Ram that resulted in an estimated coefficient of drag (Cd) of .422 for a crew cab 4x4 model – compared with a Cd of .463 for a 2008 Ram Quad Cab® 4x4 (and .42 for the original 1994 Dodge Ram!). Extensive wind-tunnel testing was conducted to hone the 2009 Dodge Ram’s exterior shape.
The shape of the front grille, hood, and exterior mirrors cuts wind resistance
A subtle circumferential notch near the rear edge of each outside mirror housing causes airflow (and dust or water, when present) to separate from the housing. This also helps keep the door glass clean
An air dam directs air flow around the vehicle to reduce drag, and cool the engine and air conditioning condenser
Full cut-line doors reduce wind noise and drag
A carefully developed curve at the leading edge of the windshield frame reduces drag
A raised lip on the cowl screen directs air flow and water toward the sides of the windshield
The cowl screen smoothes the airflow transition from hood to windshield, reducing turbulence and wind noise
Troughs created by windshield side moldings channel water over the roof rather than around to the side windows
Side windows offset from door frames were minimized to help reduce turbulence and wind noise
Side sills are lowered, extending the attached air flow and eliminating some underbody turbulence
The new front-end module has smaller gaps around head lamps to help aero performance
A large tailgate spoiler integrated into the sheet metal improves aerodynamic flow
Lowered windshield-wiper location improves visibility, as well as reduces wind noise and drag
Flush-fit fog-lamp pockets eliminate drag of fog lamps
Reduced wheel openings help decrease drag
Optimized ride heights provide aerodynamic efficiencies
All that supposed wind tunnel testing and they ESTIMATED the Cd? It went from terrible to meh
Permanent Aluminum Grill Block and Belly Pan Markmysite EcoModding Central 37 12-20-2011 02:03 PM
grill "shield" rather than block? lunarhighway Aerodynamics 70 12-17-2010 03:50 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Airdam and grill block on the Mirage BrianAbington Aerodynamics 5 10-15-2008 06:54 PM
96-00 Civic Upper Grill Block Impulse Aerodynamics 2 07-12-2008 03:09 PM
