Old 05-01-2013, 07:10 PM   #11 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
I see a cutout for the exhaust pipe, but how close does it come to the muffler itself?
There is 4 inches of fiberglass insulation in between it and the coro. So.. 4 inches.
The Following User Says Thank You to mikeyjd For This Useful Post:
aerohead (07-22-2013)
Old 07-21-2013, 11:10 PM   #12 (permalink)
Rapturee
HHOTDI's Avatar
Sippy2 - '15 Honda NC700XD DCT
90 day: 59.51 mpg (US)
Shorty - '02 Ford F150 XL
i'll bet with the addition of a Kammback you'll easily be right there!! :{)
Old 05-16-2014, 11:57 AM   #13 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
This is the closest I've gotten to doing a Kammback A little cleaner separation and I still have full visibility out my rear allowing for little interior side mirrors. If I do anything else it will be a full boat tail!
Old 05-16-2014, 12:44 PM   #14 (permalink)
Valerie - '03 Honda Civic DX
90 day: 55.79 mpg (US)
Nice work! Aren't you worried about the exhaust pipe melting the plastic?
Old 05-16-2014, 01:17 PM   #15 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
I wrapped it in fire retardant fiber glass. I ended up adding some venting in the rear as the summer temps require better air flow, and it can cause issues with the gas tank becoming a safety hazard if the temps go to high.
aerohead (05-16-2014)
Old 05-18-2014, 01:27 PM   #16 (permalink)
basjoos's Avatar
Aerocivic - '92 Honda Civic CX
Last 3: 70.54 mpg (US)
AerocivicLB - '92 Honda Civic CX
90 day: 55.14 mpg (US)
Camryglide - '20 Toyota Camry hybrid LE
90 day: 62.77 mpg (US)
My coroplast under panelling gets within 2 inches of my muffler and I have had no problems with plastic melting in 9 years and almost 200,000 miles of driving. Coroplast is made of polypropylene, which has a melting point of 266 degrees F.
aerocivic.com
The Following 3 Users Say Thank You to basjoos For This Useful Post:
aerohead (05-19-2014), mikeyjd (05-19-2014), UltArc (05-23-2014)
Old 05-20-2014, 09:06 AM   #17 (permalink)
NoD~'s Avatar
Frogger - '00 Honda Insight Gas Only (unHybrid)
90 day: 68.51 mpg (US)
A few questions...
-What exact type of fiberglass are you using?
-Is it going to retain moisture?
-Pics?
I ask because you might find some issues with it retaining a lot of moisture and causing advanced corrosion on your exhaust piping (and possibly the body of the vehicle itself). This will also keep a lot more heat on your exhaust piping, which has it's ups and downs (though I'm not really clear on the downs, honestly. A bit of research might be needed here).
I wrapped it in fire retarded fiber glass. I ended up adding some venting in the rear as the summer temps require better air flow, and it can cause issues with the gas tank becoming a safety hazard if the temps go to high.
I think you meant: Fire Retardant.
(lol, reminds me of this..)
The Following 2 Users Say Thank You to NoD~ For This Useful Post:
aerohead (05-20-2014), mikeyjd (05-20-2014)
Old 05-20-2014, 01:10 PM   #18 (permalink)
cowmeat's Avatar
Princess Carriage - '20 Ford Explorer Limited
Silver - '22 Ford Maverick Hybrid XLT w/tow pkg
Maverick Hybrids
90 day: 41.3 mpg (US)
Nice one man, hope you don't mind me copying you again!
Hopefully I'll get time to do mine this weekend. I can already feel a small difference in the length of coast just from the wheel skirts, so I think with a full belly pan I might see a big increase in the "glides"
I have everything but the plastic, and I can get pallet-sized heavy duty plastic sheets for 2 bucks each, so I'll be another 6 bucks into modding at that point.
Planning on doing a 3-piece pan, with a couple of inches of overlap and a small gap for fluid drain at each section (in case I hit high water, my area floods alot).
I'll post pics of the finished product. I posted the wheel skirt addition here somewhere the other day
The Following User Says Thank You to cowmeat For This Useful Post:
Old 05-20-2014, 02:14 PM   #19 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
Originally Posted by NoD~ View Post
A few questions...
-Pics?
White faced batt insulation. I checked on moisture after a few drives during heavy rainfall and it was damp but not soaked so I didn't worry about it after that. After having it on for a while it seemed to be retaining more moisture, so i think a better solution is needed.
