Old 09-01-2010, 02:37 PM   #1 (permalink)
The Putter - '00 Golf
New guy here driving a VW TDI
I re-found this forum while doing a google search. Aparently I found it some time ago, registered, then forgot that I registered.
I have a VW Golf TDI that I usually get 47mpg. I drive it fairly conservatively & sometimes will use hypermileing techniques. I used to own a Camry Hybrid and hypermiled that car everywhere I went which was very taxing and stressful trying to get 44 mpg out of it.
I'm interested in seeing if I can get 55mpg or more out of the Golf. I put 1100 mile trips on my car 2 or 3 times a month...all interstate. It is a long drive, 550 miles one way at 70 mph is almost 8 hours. Then I return home the next day with another 8 hour drive. I don't mind slowing down, but at 65mph it would take me 8.5 hours.
Anyway, I look forward to exploring the site.
Old 09-01-2010, 04:45 PM   #2 (permalink)
Tank - '76 El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 190 E
90 day: 37.07 mpg (US)
Angel - '88 420SEL
Last 3: 23.01 mpg (US)
Straight pipe rear muffler just a suggestion never hurts on a turbodiesel Spools up the turbo quicker and has never hurt mileage
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 09-01-2010, 04:56 PM   #3 (permalink)
2003 Ninja EX250 - '03 Ninja EX250
90 day: 87.63 mpg (US)
Saturn - '99 SL1 Base
Since most of your driving is on the highway and at a high rate of speed (in the case of speed vs. drag), you need to improve the aerodynamics of your car and lower that Cd!
Grill block, front air dam, Kamm spoiler, moon disk wheel covers, belly pan, and close up that rear wheel well.
All of these can be done tastefully.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
Old 09-01-2010, 05:06 PM   #4 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
theycallmeebryan is right on the money: for highway driving, you need to focus on aero mods.
VW's are also popular for top gear swaps to reduce engine RPM at cruise.
I'm not sure of any studies/valid tests of exhaust mods that have been shown to improve economy. Lots of testimonials, but they don't count.
Old 09-02-2010, 04:10 AM   #5 (permalink)
Chug - '96 Polo CL
90 day: 49.42 mpg (US)
I'd start with a grille block and other some tasteful areomods and..... lower the ride height, some people downlike it but VW's alway look good lower!
If it aint scrubbin' you aint 'dubbin!
good things come to those who wait, sh*t turns up pretty much instantly
twitter.com/bertchalmers
Old 09-02-2010, 12:30 PM   #6 (permalink)
Thanks for the tips! I wasn't expecting anyone to post anything more than a welcome to the forum type message on my first post.
These are some good ideas. I hadn't thought about any aeromods. I was just focusing on driving technique, tire pressure and good car maintenance. Anyone have any pics of these mods? I'll have to do some reading to find out what a front air dam and kamm spoiler are. LOL
I've thought about the 5th gear (and also thought about swapping in a 6-speed) gear swap. But any mods I do will have to pay for themselves in fuel savings...otherwise why do it? The point for me is to save money to have money.
Old 09-02-2010, 12:38 PM   #7 (permalink)
Chug - '96 Polo CL
I'd check the ratios, some 5cog 'boxes have just as tall top gear as some 6coggers!
another thing to try is seat position - I'll probably be flamed for this - but don't sit too close tot he pedals, make sure you can safely depress the brakes but have the seat far enought back that you have to consciouly pivot you ankle to acclerate rather have the weight of your foot adn leg reating on the noisy pedal.
Old 09-02-2010, 01:59 PM   #8 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 49.12 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
That's the hard way
The grille block is a good first mod.
The grille lets far too much air into the engine compartment, which leads to drag.
Closing the better part of that intake is an easy job, and can be done from the inside so it's not even visible. Watch your coolant temperatures on the trials.
Car manufacturers do the very same thing these days.
Huge grilles (see Audi, Mazda, Peugeot, but a lot of it is blanked off on the inside.
Lifetime fuel consumption :
Old 09-02-2010, 08:46 PM   #9 (permalink)
Agreed. I sit pretty far back and usually will kick off my shoes to drive barefooted. This allows me to minutely adjust the throttle with very slight pressure from my big toe. The roads are mostly flat in coastal Alabama so I try to keep an even throttle.
On my 550 mile interstate commute I will use cruise control since it is a flat run down the Florida coastline on I-10 & I-75. There are some gentle hills on the I-10 part where I see better mpgs than on the flats. I attribute this to the engine being more efficient under a heavier load going up the hills and basically coasting on the downside. I've noticed this to be true in the tdi, my wife's Mustang and also my diesel Excursion. We did a trip up to TN this summer in the Excursion by way of Mobile, AL to Tampa through S.C. then went over the N.C. - TN mountains. I made it a point to fill up at each of the different terrain breaks on the trip to get the mpg for that leg. I was surprised to see that I got the best mpgs going over the mountian and then repeated that mpg going back over the mtn on the way home. I guess it was kinda like a HUGE pulse and glide.
Interesting time test I did on hypermiling vs "normal" driving. MARTINSR Hypermiling / EcoDriver's Ed 14 09-02-2010 02:37 PM
VW Lupo crash tested by the NHTSA tjts1 General Efficiency Discussion 19 07-02-2009 08:18 AM
Any advice for driving by vacuum guage? video Chris D. Instrumentation 33 02-22-2009 12:54 AM
New USA Energy Policy NeilBlanchard General Efficiency Discussion 18 11-17-2008 01:54 PM
I took out a guy on a bicycle with my truck.. Chris D. The Lounge 16 11-01-2008 11:00 PM
