Old 09-24-2009, 10:05 AM   #1 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
New oil discoveries
From the LA Times about a new discovery, using new techniques.
And a NY Times story about this years surprising increase in discoveries.
And while *I* find these of interest, it doesn't mean to me we have unlimited resources/reserves. I see this sort of news as a little more time to get a better handle on the new and emerging technologies to get us OFF oil.
When it comes to Heroes, RENEGADES are mine!
Old 09-24-2009, 10:13 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
There are people though who believe in the oil fairy.
As well as those who would not celebrate new sources for atmospheric carbon.
Old 09-24-2009, 11:12 AM   #3 (permalink)
pgfpro's Avatar
I thought the earths center is filled with an endless gooey core of oil?
Not true???
Old 09-24-2009, 12:44 PM   #4 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.85 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 28.75 mpg (US)
Not true???
...uh, from my observations it seems more like "...the politicians center is filled with endless gooey core of _____" (fill-in the blank as appropriate)
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SIDI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-24-2009, 01:19 PM   #5 (permalink)
The abiotic theory of oil production, which implies essentially limitless oil supplies, is based on crap.
Ooops, did I say that out loud?
Anyway, I'm hoping for a soft landing to peak oil, where we get incrementally better at finding and extracting the remaining dino petro, and (rapidly) incrementally better at conserving and alternative energy sources.
Otherwise, we are in for a rough scenario.
Finest regards,
troy
2004 VW TDI PD on bio
want to build 150 mpg diesel streamliner.
Old 09-24-2009, 01:29 PM   #6 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 45.16 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
Hi,
I heard recently that we are only finding 1 new barrel of oil for every 4 barrels we use. Obviously, this is not sustainable; and obviously we are running out of oil sooner rather than later.
Old 09-24-2009, 02:57 PM   #7 (permalink)
Ecomod noob
zjrog's Avatar
Neon - '03 Neon SE
EX - '94 Explorer
Ranger - '90 Ranger
Finest regards,
troy
I have a geologist acquaintance that has thoughts on the abiotic theories. Endless and limitless? No, not at all. But he has seen capped, dry wells checked after 20 years with oil in them. He doesn't want to tender any further thoughts in that regard though.
With more discoveries, of course, buys more time. But there are still plentiful reserves that we aren't allowed to touch. My thinking is to access these resources to be completely independent of foreign petroleum. To me (a retired Navy guy), it comes down to national security, ensuring our enemies don't profit from us. But hey, what do I know...
Old 09-24-2009, 03:34 PM   #8 (permalink)
dcb
needs more cowbell
dcb's Avatar
Originally Posted by zjrog View Post
...he has seen capped, dry wells checked after 20 years with oil in them...
Yup, and the oil level in my engine goes up if I wait 5 minutes after shutting it off, its amazing
The Following User Says Thank You to dcb For This Useful Post:
roflwaffle (09-26-2009)
Old 09-24-2009, 03:35 PM   #9 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
The oil stuff doesn't bother me. the chemistry is known, just make the darn stuff like a tree farm.
To ponder making something accidentally gamma ray'd nuclear unintentionally before someone figured out how to make oil helps put the silly chore into perspective.
did you ever read where urethane top coat on cars originated?
the goo from an alcohol brewery...
lets get wasted, figure out the rust problems later.
Old 09-24-2009, 03:35 PM   #10 (permalink)
In 1983 I worked in the Texas oil field on a workover rig. That's like a mini oil drilling rig whose sole purpose is to rehabilitate old wells that are pooping out. There are a lot of tricks to increase production on older/depleted oil wells. One of the best, if you can afford to wait, is to stop pumping it for a decade. Most oil bearing formations are something like a sponge. As you pump out the oil, you deplete the local formation, and oil from further out slowly leaks/oozes/migrates/flows in to "refill" the pumped out area.
None of that requires the use of the abiotic oil theory to explain.
All other things being equal, the faster you pump a formation, the more "damage" you cause and the less you will be able to extract in the long run, all other things being equal, which they never are.
Finest regards,
troy
The Following User Says Thank You to solarguy For This Useful Post:
jkp1187 (09-30-2009)
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 06:04 PM
Article: Crude oil is getting cheaper — so why isn't gas? Frank Lee The Lounge 20 07-14-2010 02:06 AM
Restore oil additive... suspectnumber961 Success Stories 43 05-14-2010 04:40 PM
