Old 09-27-2010, 07:22 PM   #21 (permalink)
EcoModding Enthusiast
Silver Bullet - '03 Mazda Protege LX
90 day: 29.51 mpg (US)
90 day: 37.06 mpg (US)
Blaze - '17 Ford Escape
I need a trickle charger. Have any recommendations?
Also, how often do you actually key-start the engine? I've come to the realization that I should probably try to roll/bump start as often as possible when running the battery down to such low levels ('til I get the charger).
Old 09-28-2010, 04:00 AM   #22 (permalink)
See ya at the next light!
Slowest. Altima. Ever. - '05 Nissan Altima SE
90 day: 45.91 mpg (US)
Amazing. Just amazing. Further proof the driver determines the mileage, not the car or the EPA. But it helps to have a Civic. I had a 5 speed '97 LX a few years ago. It had a few dents, I wanted something nicer, so I got the Altima. I'm wondering what my numbers would be like if I kept it. The extra 1.9 liters in the Altima don't get me to work any faster.
I just checked and I only saved one picture of it
My only concern is running the tank to empty, or near empty, may result in premature fuel pump failure. Without singling out any car builders in particular, I know it can be a major problem.
Old 09-28-2010, 09:08 AM   #23 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
Trickle charger: I got a cheap one at Harbor Freight for under $10. It does the job for what I need. Going alternatorless would require more charging, so you'd have to get a good one. Daox just tested a couple: http://ecomodder.com/forum/showthrea...tml#post193639
Vegas: Great picture! That looks just like my car. Same engine and trans, too. (I don't have the sunroof, spoiler, clear taillights, backup lights, rims, etc) With what you're doing in that Altima, you'd be scaring me with your numbers.
About the fuel pump, I share your concern. I only run it low when I can get a distance record. That means I did so on the last three tanks. Now, however, I'll be filling sooner. Cooler weather and morning school dropoff duty are knocking my numbers down a notch. If I can't get a new record, why push it so far?
Old 10-03-2010, 04:47 PM   #24 (permalink)
Talking Fantastic!!
Thats some good drivin there!!!
Old 10-03-2010, 04:51 PM   #25 (permalink)
Red face Dumb question...
Now why are you trickle charging? Are you running alternator less? I am new to this stuff and tryin to take it all in... thanks!
Old 10-04-2010, 10:50 AM   #26 (permalink)
Hypermiler
Wagons
When I do a lot of EOC (engine off coasting), the battery runs down a bit. All the time the engine is off, the alternator is not charging the battery, but the lights and ecu are still drawing power. I trickle charge to keep it topped off. A couple cents of electricity is cheaper than a couple dollars of gas to leave it idling for the coasting parts.
Old 10-04-2010, 12:38 PM   #27 (permalink)
Racer XD - '06 Hyundi Elantra GT
90 day: 33.26 mpg (US)
Racer XD 2013 - '06 Hyundi Elantra GT
90 day: 31.48 mpg (US)
Racer XD 2014 - '06 Hyundi Elantra GT
Racer XD 2012 - '06 Hyundi Elantra GT
Racer XD 2011 - '06 Hyundi Elantra GT
1.5 Watt Solar Battery Charger
I have one that is a 1 watt. And have never had any problem with low charge. Once left a light on in my car and went to start it and noticed it was on and turned the key and it started right up. I got mine for $10 - $15.
2006 Hyundai Elantra GT 2.0L (Manual)
Weapon-R secret weapon intake with ram air kit ScanGauge Belly Pan
http://www.cars.com/ City 27 mpg - Highway 34 mpg
http://www.fueleconomy.gov/ City 23 mpg - Highway 31 mpg - Combined 26 mpg
Old 10-13-2010, 05:11 PM   #28 (permalink)
Cinco The Miata - '90 Mazda Miata
Team Mazda
Sports Cars
90 day: 36.13 mpg (US)
Oscar Wilde - '02 Honda Metropolitan
Motorcycle
90 day: 94.9 mpg (US)
Wow, I am truly impressed you can squeeze that kind of mileage out with so few mods. I'm going to have to start doing some engine off coasting.
Old 10-13-2010, 07:45 PM   #29 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Start with the engine on
Before you go coasting with the engine-off, check out your car's remaining braking capacity.
Power steering quits right away.
Power brakes fall away more gradually, but the brakes can get very hard to operate unassisted.
The original Miata isn't too heavy, so braking unassisted might work.
On my car the brakes get rock-hard quite quickly and stopping distances are greatly increased - the reason I'm not even considering engine-off coasting.
Old 10-14-2010, 09:13 AM   #30 (permalink)
Hypermiler
Wagons
Good points. My power steering gives very minimal assist, so there's little difference between on and off. Brakes - I have about four good pumps available in mine, and I can still stop it without the boost too. It does take more effort from me, but the brakes stop the car just as well. I would advise testing it out so you know what to expect. If I know I've used the brakes three times (one more and it runs out), I'll do a quick bump-start then key off again, just to rebuild my vacuum boost.
(cleanmpg) 48-Contiguous State FE World Record Overall groar Hypermiling / EcoDriver's Ed 22 06-12-2013 08:16 PM
News: new world record of 68 MPG around the lower U.S. in a Jetta TDI MetroMPG Hypermiling / EcoDriver's Ed 4 08-20-2009 04:33 PM
Solar electric unmanned plane sets record: 83 hrs aloft MetroMPG Fossil Fuel Free 2 08-24-2008 03:55 PM
New MPGe & distance record in the ForkenSwift MetroMPG Success Stories 3 08-18-2008 03:02 PM
News: Chrysler Canada sets 4-cyl sales record MetroMPG General Efficiency Discussion 0 01-04-2008 11:17 AM
