New RTD Explorer!! Beta Testers Needed!!!
Hello Everyone,
Its been WAY too long since I have been on Ecomodder. Ive been lurking but mostly quiet. I have had an urge to get a new version of RTD Explorer out into the wild and Im looking for willing beta testers as a lot has changed. I currently don't have a Revolt controller running. :( Back in 2012, Kyle, (who does most of the developing on RTD Explorer) decided to improve the interface and make the graph more readable. He added some stuff in the settings tab to adjust color and line width of each graphed line. I am looking for anybody with experience(preferred, but not necessary) with the original RTD Explorer and computer knowledge that can help test this version and report bugs back to me. Please contact me through email: adamj12b at gmail dot com. Thanks for the help!! |
I have the latest DC controller running, codenamed Stinky diaper :D
Laptop is running windows 7 RTD_EXPLORER installs on windows 7 and runs. The rtd-period is set to 100 ms and between 1 and 30 updates are logged before the terminal on the right freezes. It starts again when you disconnect/connect. Debug mode does not appear to do anything different. But it stops just as quickly. There seems to be issues communicating when the controller is running. I have it logging in Hyperterminal on an older XP SP2 machine - the issue may be noise, but I don't see the noise changing between logging on different laptops?:confused: I'm using a crappy USB to serial adapter ... is there a brand or a chipset that works well that I can use? |
Is the rtd string that the controller outputs in the same format as the original controller? If not, that could be the problem.
I have always had the best luck with ftdi based adapters using the ft232r chip. -Adam |
1 Attachment(s)
The output string looks like it is the same. I've attached an example.
This one looks like it matches
https://otvtech.ca/catalogue?page=sh...=usb+to+serial But it has an extra letter on the chipset - FTDI - FT232RL |
Yes, that one should work for you.
I dont see any attachment of the data output. -Adam |
Your custom firmware is not outputting an AH value.
TR=000 CR=000 CF=012 PW=000 HS=0261 RT=0716 FB=00 BA=000 AH=xxx.x which is causing the REGEX in RTD Explorer to kick out the string as bad data. Also, RTD Explorer is looking for an RTD-Period set to 100 not 1000. -Adam |
I saw the command from RTD explorer set RTD-period to 100 ms, so I think that part is OK AH=xxx.x ... OK - I'll check the code and see if it is a formatting error on the string or if there is no numbers feeding that part yet. If there are no numbers I'll hard-code 42.0 .. the answer to Life, the Universe, and EVERYTHING! I guess I'll hold off on the new USB to Serial until I get the AH changed. |
Thanks for the quick response Adam.
RTD Explorer is expecting exactly this format ... can I put other information on a second line? ie Code:
first set of data |
