Old 11-28-2010, 11:39 AM   #1 (permalink)
Driving the TurboWeasel
New rubber brake hoses...
So I replaced the rubber brake hoses on my rolling couch since one of them was looking a bit leaky. All the hoses were soft as spaghetti, and likely degrading inside. Turns out one of them was dragging just a little, as my instant MPG on the ScanGauge went up about 1 mpg on the highway. The tank after replacing them was better than the previous tanks by about 1 mpg or so, even with colder temperatures and snow tires. Can't complain when maintenance boosts FE!
2012 Chevrolet Cruze Eco 6MT
Old 11-28-2010, 03:11 PM   #2 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
"...dragging just a little..." could refer to either:
• disc caliper that wasn't retracting.
...or...
• drum shoe that wasn't retracting.
...which?
Old 11-28-2010, 04:34 PM   #3 (permalink)
I think a caliper and a wheel cylinder. The drums were always warm upon getting back from driving around my little town. And, one front wheel was always dustier than the other, confirmed when the pads on that side were more worn.
The car coasts better down hills better, too. On hills where I lost speed before, the car now holds a steady speed. Something freed up, the car stops on a dime, and I'm happy.
Old 12-04-2010, 12:44 PM   #4 (permalink)
'91 CRX - '91 CRX DX
90 day: 34.91 mpg (US)
...or...
...which?
Either way, it's the same physical defect manifesting itself. The rubber inside the brake lines degrades and swells up until the passage through the line is actually pinched closed. Stepping on the brake pedal generates hundreds to thousands of PSI of pressure, so liquid can still push past the pinched area to the caliper or wheel cylinder, resulting in normal brake operation. However, when the pedal is released fluid only flows back until pressure at the caliper/wheel cylinder drops to the point where it matches the restriction that the collapsed hose presents. That means a certain level of residual pressure being applied to the brake, even when the pedal is released.
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
Certain subjects are immune to logic? Frank Lee The Lounge 185 02-03-2011 09:02 AM
Big project-F250 pulling 20x8.5 enclosed trailer 5.0 Junkie Aerodynamics 70 04-11-2010 01:10 PM
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 68 02-21-2010 08:45 PM
Instrumenting Prius brake problem bwilson4web Hybrids 5 02-15-2010 02:34 PM
