Old 05-25-2018, 01:52 PM   #1 (permalink)
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
Ioniq hybrid has no lead acid battery at all
So it looks like the Ioniq hybrid has no lead acid battery at all, a first for mass market cars.
Instead, they have a built-in 12v lithium pack attached to the main hybrid battery/traction battery. That means no float charging an inefficient but tough battery chemistry all the time.
https://www.caranddriver.com/news/ho...tarter-battery
I can not find the source, but I read an article once that stated that less than 20% of the energy that goes into a typical car battery ever comes back out due to the Peukert effect and the constant maintenance of a full SOC. Does anyone have a citation about that?
Sam
The Following User Says Thank You to samwichse For This Useful Post:
redpoint5 (05-25-2018)
Old 05-25-2018, 01:58 PM   #2 (permalink)
Stubby79's Avatar
Firefly EV - '98 Pontiac Firefly EV
90 day: 107.65 mpg (US)
Little Boy Blue - '05 Toyota Echo
90 day: 33.35 mpg (US)
BlueZ - '19 Nissan 370Z Sport
90 day: 17.19 mpg (US)
https://www.otherpower.com/images/sc...Efficiency.pdf
Points out that charge efficiency over 90% SOC is under 50%. Seeing as this is where car starting batteries operate, yeah...it's pretty abysmal!
Ok, might be time to do something about that in my car...
Old 05-25-2018, 05:53 PM   #3 (permalink)
If all you ever do is float charge and barely ever use the battery then 20% sounds low.
A typical car battery takes about an amp to maintain float voltage. A larger truck batter could be 2 to 2.5 amps.
