Old 08-03-2011, 05:50 PM   #1 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
New tires - size up!
I went into to RADIAL TIRES of SACRAMENTO this morning after researching sizes this past weekend.
Background:
THe 02 Q45 Sport came from the factory w/245/45/18 (26.5 inch diameter)on 18x7.5 alloy rims.
At 60k miles I went to a 255/45/18 (27.0" diameter)
The base of the Strut tower on the front is the limiting factor to how tall a tire can be without using 30mm spacers( BAD)
We tried a 245/50/18 and there is an 1/8 inch gap!!!
THe diameter is 27.7 inches.
The tire weighs 31lb and the current size weighs 30 lbs.
They ordered them today and will install tomorrow.
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 08-03-2011, 06:41 PM   #2 (permalink)
318iS - '95 318iS
Team m8
90 day: 34.36 mpg (US)
Track Slag 535 - '89 535i Sport
Team m8
90 day: 19.12 mpg (US)
328 Shooting Brake - '97 328i Touring SE
Team m8
90 day: 24.32 mpg (US)
You could cut off the spring platform and fit threaded sleeves so you can fit 2.5" diameter springs
My BMW 328i Mods thread
http://ecomodder.com/forum/showthrea...ead-21561.html
UK MPG for the 328i Shooting Brake
US MPG for the 328i Shooting Brake
UK MPG for my 318iS (currently piloted by the Burd...)
US MPG for my 318iS (currently piloted by the Burd...)
Old 08-04-2011, 03:47 PM   #3 (permalink)
mcrews's Avatar
Got the tires on today.
new 245/50/18 27.7" dia. at 55mph 1625rpms
old 255/45/18 27.0 dia at 55 mph 1725rpms
will do mpg runs in a day or so.
ECO MODS PERFORMED:
First, Grille Block
Old 09-05-2011, 11:30 PM   #4 (permalink)
mcrews's Avatar
as you can see there is no more room!!!
talk about cutting it close!!!
ECO MODS PERFORMED:
First, Grille Block
Old 09-06-2011, 12:09 AM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...do you think there's "contact" when driving at high speeds and centrifugal forces are attempting to "enlarge" the wheel diameter?
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-06-2011, 10:08 AM   #6 (permalink)
Vekke's Avatar
Siitin - '98 Cordoba Vario
90 day: 58.56 mpg (US)
Starppa - '96 Starlet
90 day: 35.06 mpg (US)
Aeroscania - '97 P94D 260
90 day: 9.35 mpg (US)
VW Lupo 3L --> 2L - '00 Lupo 3L
Diesel
90 day: 63.49 mpg (US)
If you install coilover suspension you dont need so big spacers to get more room. Or change you ET on your wheels.
www.tuneko.com
Less drag = Less fuel
Old 09-15-2011, 02:46 PM   #7 (permalink)
mcrews's Avatar
Well, it's been a month. Had a round trip from Sacramento to LA.....450 miles each way.
No problem with any rubbing.
I had some obdII codes that I had to resolve. And am still addressing some ecu issues pior to my TTT (trip to texas) on Oct 12.
But I just ran a brief highway run.
At 63mph 1775rpms got 30.9mpg (didnot have the grill block or the front underbelly panel in place)
epa is 22mpg highway.
ECO MODS PERFORMED:
First, Grille Block
Old 09-15-2011, 06:20 PM   #8 (permalink)
...beats walking...
...cars need an "electronic" wheel diameter compensation "box" to allow for use of different diameter wheels & tires!
Old 09-16-2011, 12:38 AM   #9 (permalink)
mcrews's Avatar
somebody was posting that in europe it's illegal to go up or down in size........
I run a garmin gps on the dash right above the scangauge, so it gives the correct speed.
That way I don't tie up one of the 4 displays on the scangauge.
ECO MODS PERFORMED:
First, Grille Block
Old 09-16-2011, 12:40 AM   #10 (permalink)
mcrews's Avatar
Why would I want to ruin the electronic suspenion........
ECO MODS PERFORMED:
First, Grille Block
