Old 01-03-2010, 12:22 AM   #1 (permalink)
New Vehicles / Old vehicles
Hello again,
I seem to have a way of infuriating people on this website, but I'll try once more to make a point, this time , (hopefully) without pissing you off...
I had a Ford Ranger that I was ecomodding the heck out of, to try and get the best mileage I could...after all sorts of mods, I got no more than 10% better fuel economy than factory...the usual list...air dam, wheel covers, hypermiling, tonnaeu, etc.etc.
To cut it short, at the end of last Summer the Ranger was stolen. After all the trouble I had spent on it, not to mention all the money I had spent on it over the years.
I was mad, I was sad, and then I was finally relieved when I got my insurance check! Less than I paid, but more than I expected...oh well, life goes on.
Bought a Geo Tracker (I know, all you 'pros' are mad at me for not owning a metro!) instead...still has 4x4, down to 4 cyl from 6, manual from automatic, and lightweight from heavyweight.
Realized I don't need the truck most of the time, heck, never...I'll use a trailer, when I need a small truck, for the rest of the time, I'm carrying 7 feet less vehicle!
It's a 1991, but it's an 80's design...less B.S. inside. All that plastic crap and metal crap is weighing down the cars... I've read all the this mods, and that mods and the other mods. It all comes down to simple physics...power to weight ratio...aerodynamics helps, but no more than dropping a few hundred pounds. Half the aeromods on these lists involve making things smaller, or deleting them...(in case you didn't notice, when you make something smaller, or get rid of it altogether, it weighs less!)
So my 2010 resolution for ecomodding is try to work on your weightloss program, and the new figures for your car will be better!
Talk to ya'll soon!
Old 01-03-2010, 12:30 AM   #2 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Sorry, aero does have something to do with weight, but not the way you're insinuating.
BTW - If you really wanted to, I believe there is a diesel that bolts into your Suzuki Sidekick clone. I'll have to look it up, though.
Old 01-03-2010, 12:41 AM   #3 (permalink)
Maroon Ballon - '98 Town & Country LXI
90 day: 26.42 mpg (US)
MaEsTRO - '95 Metro 5spd hatch, 3 cyl
Aerodynamics and gravity are separate realms of physics, and neither are mutually exclusive.
If you have a point to make, I think you can do it without being combative, but some people just feel a need.
Old 01-03-2010, 01:01 AM   #4 (permalink)
gascort's Avatar
Gascort - '93 Escort Wagon
90 day: 43.01 mpg (US)
I guarantee the aerocivic is heavier than it was in stock config., and it gets 70 mpg.
Totally depends on the driving you do. Jackrabbit low speed driving and mass makes all the difference. Higher speeds and aero becomes significant quickly.
Kudos on getting the smaller vehicle though. I'm sure it will get better mpgs than the ranger, and it rides high off the road, which I'm sure you are used to.
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-03-2010, 11:55 AM   #5 (permalink)
I for one can't see why anyone would disagree. I don't want much of the stuff that adds extra weight to newer cars - and that especially means having four seats, when I just want two, or body styles that look like over-filled muffins. A car designed the way I'd like would have lower weight as well as a smaller A.
As for the Cd part, of course doing something like the aerocivic adds weight, because it's adding all the fairings &c to the basic body. But suppose you started from scratch, and removed a lot of the now-hidden original bodywork?
Old 01-04-2010, 05:33 PM   #6 (permalink)
5 Gears of Fury
War_Wagon's Avatar
Lumpy - '00 Insight
90 day: 49.98 mpg (US)
Grendel - '00 Firefly
90 day: 39.17 mpg (US)
Salty - '91 Tercel DX
90 day: 35.27 mpg (US)
These guys make a kit to install a VW diesel, maybe that's the one you are thinking of.
ACME ADAPTERS Suzuki Samurai Turbo Diesel
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
Old 01-04-2010, 06:37 PM   #7 (permalink)
Steve - '92 Festiva
Ok, I lied. I thought that Suzi had a bolt in engine, but I'm apparently mistaken.
However, the 1.3 that was available, I believe is the G-series engine, which makes the G10 and G10T options as well.
Old 01-04-2010, 09:18 PM   #8 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
C'mon -- both weight and low drag are important. Both reduce the requirement for power, so reducing either/both will help improve efficiency. Weight may be more important for stop and go (city) driving, and aerodynamics is more important for sustained driving at higher speeds (highway).
Rolling resistance is the third leg on this stool...
I want to get to the bottom of this ethanol killing my mpg Nerys General Efficiency Discussion 172 07-20-2010 01:06 AM
Diesel- and Hybrid-Powered Vehicles Can Provide More Societal Benefits than Gas-Power SVOboy General Efficiency Discussion 11 01-03-2010 02:03 PM
Recovery rate of end-of-life vehicles blueflame EcoModding Central 1 02-09-2009 09:31 AM
source of mpg ratings of older vehicles? kp3ft EcoModding Central 2 12-01-2008 11:43 PM
Tested vehicles in the garage steensn Forum News & Feedback 1 07-11-2008 03:48 PM
