Old 10-11-2010, 07:49 PM   #1 (permalink)
Newbee needs help
I received the pre-assembled module on 10/8/10. I have finished installation and checked and cross checked the connections but I am not getting any DATA. Everything is registering 0000.
I must admit the connection you chose is a pain to work with.
Can I get some support/
I am on a Toyota previa 91.
Old 10-15-2010, 11:45 PM   #2 (permalink)
Well nobody replied , so I figured it out. Thanks for viewing.
Old 11-20-2010, 04:44 PM   #3 (permalink)
Does mpguino work with OBD11 vehicle? If so wich pins on the OBD11 plug match the 4 wires on the mpguino?
Old 11-20-2010, 05:07 PM   #4 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
it does not connect to the obd port, it connects directly to the injector and speed signals.
Newbee ScangaugeII/MPGuino HELLLP!!! fredkt Introductions 2 07-19-2010 05:30 AM
Newbee with hydrogen kit mechanic999 EcoModding Central 20 05-27-2008 02:17 AM
