Old 08-14-2011, 05:46 AM   #1 (permalink)
Newbie - in Australia
Hi - great forum, lots of interesting stuff here, I drive a 1999 toyota camry V6 auto. I am tempted to start doing more but I have taken out about 70kg by swapping the spare tyre for a can of goo, leaving out the boot floor / lining, removing the rear door electric lock actuators, some rear parcel shelf sound deadening - which did not seem to make any sound difference.
Matt
Orange NSW - about 180 miles West of Sydney
Old 08-14-2011, 07:10 AM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
AeroTrix - '06 Matrix base
90 day: 42.69 mpg (US)
Welcome to EM!
Have you looked through our wiki for great mod ideas and user data?
Car MPG Efficiency Modifications Main - EcoModder
Old 08-15-2011, 05:33 AM   #3 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Not the most economical vehicle to start with, but some folks on here have gotten good results from big automatics, so there's hope
Change your driving style and habits, using the
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
as a guide.
Start with the less visible mods :
More pressure in the tyres.
Many on here run the max. sidewall pressure on the tyres, some run even higher pressures. I run 3.5 bar (51 psi) the rated max of the tyre.
Upper grille block - partial or even full if that doesn't lead to excessive heat in the Ozzie summer.
It'll always help a bit, but weight reduction helps most when you're doing much stop & go / city driving.
On the motorway; the effect is hard to spot.
Obviously, a small bit here and there will help the overall fuel efficiency.
Lifetime fuel consumption :
