Old 03-31-2008, 02:40 PM   #1 (permalink)
fabrio.'s Avatar
tigra AERO - '96 opel tigra
lambda sensor for lean burn engine
Yes, I will go to modify the AFR ratio in my engine, but in the meantime, I store all interesting documents that they me able to serve to me.
three of this you can see at the address below.
http://cafee.wvu.edu/Assets/Document...s%20Engine.pdf
http://www.bosch.se/content/language...58_till_60.pdf
This link, is about the LSM-11 lambda sensor with a range of Lamb > 1.0...1.5 (for special applications up to Lamb= 2.0)
Old 03-31-2008, 04:15 PM   #2 (permalink)
fabrio.'s Avatar
http://cafee.wvu.edu/Assets/Document...0Operation.pdf
How to smoothly bump start / clutch start an engine MetroMPG Hypermiling / EcoDriver's Ed 76 03-22-2014 07:52 AM
Engine braking without using fuel idea Dane-ger EcoModding Central 38 02-04-2010 10:35 AM
Heat engine block for efficiency? bennelson EcoModding Central 43 08-12-2008 09:45 PM
Coasting experiment: engine on VS engine off on a fixed route = 12.9% gain MetroMPG Hypermiling / EcoDriver's Ed 6 02-22-2008 08:38 AM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
