Originally Posted by jason1973tl
I did read that the cd is .25 for the air bag suspension and .26 without. It must lower the car somewhat.
With a smooth belly pan the lower cd version may have more ground clearance.
Mpg said
The only revision I'd make is to drop the suggestion that the car's aero is in any way exceptional. Given its smooth belly pan and minimal cooling requirements - 2 areas that contribute significantly to drag in "regular" vehicles - it's anything but.
