Nissan releases Note e-Power series hybrid in Japan
Nissan Note e-Power Hits Japanese Streets
[ADMIN NOTE: see this thread for more details & discussion about the Note e-Power -- http://ecomodder.com/forum/showthrea...ery-34499.html ] Quote:
We will see if nissans take on a series hybrid ends up being a more efficient series hybrid than before.
Something is missing in that description of the drivetrain. A 1.5kWh battery seems to be too small to be the sole power to move the car with a 40kW motor. That will be quite a high discharge rate leading to very short battery life like the R/C batteries get. The Honda Accord Hybrid uses 6.7kWh and the engine clutches in to the wheels at highway speed.
Pretty sure the Accord Hybrid (non plug-in) uses a 1.3kWh lithium. I believe the battery is only there to provide power in addition to the peak the engine can produce - e.g. if you're drawing 100kW, the engine might be making 80 and the battery giving up the extra 20 until you're done accelerating.
You are right.
. 1.3 kWh Li-Ion battery Eight-year/100,000-mile or ten-year/150,000 mile Li-Ion battery limited warranty, depending on the state of purchase/registration. . 2017 Honda Accord Hybrid Press Kit - Powertrain - Honda News . I guess the engine can start up if you want anything more than the instantaneous power that the battery can give. |
Is there any real world fuel efficiency data on the series hybrid Note such as Fuelly or Spiritmonitor? All previous series/ parallel cars were more efficiont than series only hybrid cars.
This a classic case of cheap and fast sells Further Nissan has no plans of selling the low cost epower Note in the US , Instead we will get expensive epower mini vans and SUVS Nissan wants to use this option only on fully loaded large vehicles, Another fail in my book, let’s hope $5 gas makes them come to their senses |
Test ratings in this thread, first post: http://ecomodder.com/forum/showthrea...ery-34499.html Dunno about real world. |
[QUOTE=rmay635703;570639
Further Nissan has no plans of selling the low cost epower Note in the US [/QUOTE] The company has said they will: http://ecomodder.com/forum/showthrea...tml#post559361 (I should just merge these threads, but it'll make a dog's breakfast. I think I'll close this one and post a link to the other in post #1.) |
