Old 03-24-2012, 11:35 PM   #41 (permalink)
Lead-footed Econewbie
Ceffy - '97 Nissan Cefiro 25 excimo
90 day: 25.21 mpg (US)
Demio - '07 Mazda Demio Sport
90 day: 30.99 mpg (US)
From looking at an older SAE paper on Indycar aero,if the car is Cd 0.24,then its drag would be about 79.5% lower than a typical racer.
At" 60% less," its Cd would have to be based on an Indycar without any wings or pods,just body and exposed wheels.
Interesting. Did the paper give a range for Cd? If so was the higher value and Indy car in it's maximum down force set up, since wings are adjustable?
When I saw .24 Cd I just assumed that was achieved by ground effect being much more efficient than wings.
Old 03-26-2012, 06:23 PM   #42 (permalink)
Indycar
In the paper,the body alone had Cd 0.24,when wheels were added Cd 0.54,when the wings were added,Cd 1.17.Ground effects and wings produced 3,500 pounds of down force on a car which has a static weight of 1,400-pounds and could conceivably race inverted,as the induced negative lift easily exceeds the vehicles weight.
Old 03-31-2012, 04:11 PM   #43 (permalink)
wdb
lurker's apprentice
PlainJane - '12 Toyota Tacoma Base 4WD Access Cab
90 day: 20.98 mpg (US)
That's an old F1 hack; above 60mph or so, a modern F1 car generates enough downforce that the car could race upside down.
The Following User Says Thank You to wdb For This Useful Post:
aerohead (03-31-2012)
Old 03-15-2013, 10:52 PM   #44 (permalink)
It's back....
...and even uglier.
The Following User Says Thank You to ennored For This Useful Post:
aerohead (03-16-2013)
Old 03-15-2013, 11:05 PM   #45 (permalink)
It will be easier to see, now. They did get bumped - literally - out of two races they have been in.
Le Mans has all enclosed cars now.
