Old 07-10-2009, 08:58 AM   #91 (permalink)
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Sedan 1.6 Base
90 day: 39.65 mpg (US)
For short trip commuting, a full grill/valence block may work fine. My typical trips are longer than 50 miles. I took the valence block off before a 3500 mile roundtrip into a remote area during summer heat.
What I am seeing is that instead of running at about 200F with the grill and valence blocked, the car is running at 185F with the grill blocked and valence open.
For short trips, fast engine warm up is very important. For long trips, I think that reduced temperatures may cause less stress on the motor and less decay of rubber parts.
It would be interesting to measure the mpg difference between an open valence, blocked valence with moderately sized port (80 square inches or so), and a completely blocked valence.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
Old 07-16-2009, 05:30 PM   #92 (permalink)
marcusmodder
orange4boy's Avatar
The Golden Egg - '93 Previa DX
90 day: 26.97 mpg (US)
Chewie - '03 Prius
90 day: 48.55 mpg (US)
Nice work. I like the grille blocks. Love the storm trooper visual pun. Loved the boat tail/wing tail. May it rest in pieces.
Regarding the Versa forum, I have to say you have a great deal more patience for idiocy than I do. Those tuners can be asses but then they are probably compensating for "shortcomings" in other areas. They will hopefully grow up one day.
In my youth I was a tuner and had a VW bug that I lowered / hotrodded. I got plenty of jeers and negative comments from the V8 gang but I loved what I was doing and just ignored them. I got 35mpg though, probably from P&G between lights
Keep on modding!
"I'd love to have an affordable, efficient hydrogen car. I'd park it next to my unicorn"
Review: 2008 Nissan Altima 2.5 S, CVT RH77 General Efficiency Discussion 10 03-09-2010 02:40 AM
LA Auto Show: Nissan, 370Z, Cube, etc SVOboy EcoModding Central 1 11-20-2008 01:41 AM
Nissan mods the Versa: fuel economy up by 1 MPG MetroMPG EcoModding Central 28 11-18-2008 07:38 PM
Nissan raises the bar: networked, onboard, "multiplayer" fuel economy instrumentation MetroMPG Instrumentation 12 02-07-2008 04:01 PM
Dan Neil for president! (LA Times Nissan Cube review) MetroMPG General Efficiency Discussion 2 01-30-2008 01:03 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
