Originally Posted by wagonman76
Bingo.
I don't see how it will do anything more for your engine than the air that already comes in through the intake, or that fills the empty space in your gas tank.
Sounds to me like a way for Shell to scam you for more profits. If they aerate the fuel at the pump, you are getting less actual fuel per gallon because the rest is just air.
They can't legally aerate the fuel at the pump to add anything to it. The pumps are monitored and certified by the FTC and often by state governing bodies as well.
Any fuel additives would have to be added well before the pump stations ever got it.
The only logical thought that I see, is that somehow, they're bonding nitrogen with other molecules in the fuel, creating a slightly different composition altogether. The problem with this, is that it's still going to just be more nitrogen, less boom.
